Saito Gas Engine muffler maintenance
Hello,
We have been experiencing carbon build-up in the Saito Gas Engine mufflers that we have had in use for some time. Noticing a gradual decrease in power we and the factory started looking into the innards of the mufflers and discovered quite a build-up of carbon. We have posted a Maintenance tip here:
http://www.horizonhobby.com/ProdInfo...bon_072011.pdf
For your review. I hope this helps anyone having similar issues
Sincerely,
Pete
RE: Saito Gas Engine muffler maintenance
ORIGINAL: spaceworm
Thank you very much. However, what oil and at what mix ratio was used in the cited engine? Thanks again.
Pete
