FUEL LINES
FUEL LINES
hi all,
havent been into petrol / gas type engines for long, I am having problems with the fill connectors, the plug on the fill end of the fill line, it is almost like it is stuck in with CA, I have to use a couple of pairs of pliers to get the stopper out, to fill the tank for the next flight I use crimped Brass tubing, I also have a crome finish stopper, same problem with both.
Oldtimer.
Oldtimer.
IL
RE: FUEL LINES
T Ghost,
I don't think that helps unless you are marketing those.
Like the teacher used to say in class when you got caught chewing gum, "Do you have enough for everyone?"
I'll take five....!
I'll take five....!
RE: FUEL LINES
ORIGINAL: kmeyers
T Ghost,
Like the teacher used to say in class when you got caught chewing gum, ''Do you have enough for everyone?''
I'll take five....!
T Ghost,
I'll take five....!
I don't have the equipment to more than what I use. Photo, brass one fuel, Alloy one smoke.
Cheers
RE: FUEL LINES
ORIGINAL: The Ghost
Sorry, I will remove the post so you all don't get to upset, supprised that this has not been marketed before. The OD thread is 10mm, cap thread is 8mm(RH for gas, LH for smoke) and the filling fitting is 1/4''.
Cheers
ORIGINAL: kmeyers
T Ghost,
I'll take five....!
T Ghost,
I'll take five....!
Cheers
http://www.chiefaircraft.com/radio-c.../sli-2610.html
one nipple can be blocked off.
