Throttle pushrod on DLE 30
Old 08-04-2011 | 03:35 AM
Default Throttle pushrod on DLE 30
Hello.
I am thinking of using a metal pushrod to activate the throttle arm. The throttle arm is made of non-conducting material. Plastic ball connectors will be used at both ends.
Is it safe to use the metal rod ? Will there be electrical interference considering that the throttle arm is non-conductive ? What is your experience ?
Old 08-04-2011 | 03:44 AM
My Feedback: (159)
Default RE: Throttle pushrod on DLE 30
I have had no problem using a steel braided cable set up as you indicated. If you a concerns, you can always use NYROD
Old 08-04-2011 | 05:05 AM
ORIGINAL: VIRGINIA MODEL BUILDERS
I agree....good answer. Capt,n
Old 08-04-2011 | 05:15 AM
My Feedback: (19)
On most of my gassers, I use a solid steel rod with nylon ball ends at each end bolted to the throttle arm and servo arm. Simple and reliable. DuBro makes some nice smaller ball ends that use 2-56 bolts through the brass ball. Plenty strong enough for a throttle application. Of course these also work well for the choke linkage.
Old 08-04-2011 | 08:50 AM
ORIGINAL: tomd-RCU
Hello.
Plastic ball snap connectors are not a good idea on this size gasser, use the ball link with the thro bolt type.
Karol
