valid carb tuning technique
Old 08-30-2011 | 11:06 AM
Default RE: valid carb tuning technique
The important one coveing this thread's subject is a full time pasted sticky at the very beginning of the gas engine forum. It never moves, nor does the contents. It only expands as new info is added.
Old 08-30-2011 | 11:13 AM
Antique's Avatar
You people can yak all day long about carb tuning, the bottom line is the end result is the same, the pathway to there is different...
2 turns open, start engine...Max the high...Idle to about 1800, try transition..lean the low until t he transition disappears...Richen low until transition returns...Re check high for max, go fly..Fine tune as needed after flying...Takes abvout 5 minutes if you're slow...
Addition to Pat;s signature=====Truth aways wins IF the readers are open minded enougn to BELIEVE it, not all the myths posted by so called "experts" found on all forums...
YOu go PAT [>:]
