EME new engines, 35,60 & 120 twin
Old 12-31-2012, 05:34 AM
  #151
closetguy
My Feedback: (13)
Default RE: EME new engines, 35,60 & 120 twin
can't tell if it increase the rpm, sense i started with the FB ring from first start up.as far as i can tell from other EME60 are getting,not much of a increase over those,but that shows how well the cylinder and EME ring are sealing.it may have made it smoother running,going from the other engines that i used the FB ring in.
the engine is running 300 rpm's less than the DA,if you can rely on those reports.some i can match those number's others i am just a little less,so it is real close.with a 23-8 prop i can match all numbers,with the Falcon 24-9 i am with in that 300 rpm's.also i am getting the same exact rpm's that the EME video shows.and the same exact numbers that OS is stating for there new 60.
as far as the DA60 i think it is better built engine and will last longer with out a rebuild.but i can rebuild the EME myself when the time comes,so it's not a big deal.
the DA has had some problems with midrange surging or burble some have been complaining about, and DA answer to that is to retard the timing as far as possible.all that does is detuned the engine.some guy's have been replacing the DA ignition with a rcexl and the rough idle and the mirange surging and or buble is gone.
Old 12-31-2012, 10:29 AM
  #152
ramoooo
thanks,
that really helps. Now I have to figure out if I'm going to keep it or not.
if I have to buy a replacement ignition, then the difference in price would have gone up and I'm not sure if thats worth it for me. I might just go EME and save close to $260.
will have to think about it
thanks
Old 12-31-2012, 10:33 AM
  #153
taildragger21
My Feedback: (197)
taildragger21's Avatar
ORIGINAL: ramoooo
thanks,
thanks
What replacement igniton.. RC EXL is the best out there ..
Old 12-31-2012, 12:50 PM
  #154
BarracudaHockey
BarracudaHockey's Avatar
A Bowman ring will help any mass produced engine on the market.
Old 01-02-2013, 07:21 PM
  #155
Arizona Flyer
My Feedback: (14)
So my engine running rough problem (EME 120) was a bad ignition. As someone suggested earlier, I switched the plug wires and sure enough, the problem switched cylinders. I should have a new ignition within a week or so.
Ramoooo - If you can afford the DA, that is a no brainer man. Everyone compares their engines to DA, therefore that is what you should run if you can afford one. I have several but as I was ranting about earlier in this thread, I am just trying to keep flying on a budget. The EME 120 is pretty close to half the price of a DA by the time you buy the exhaust. I thought I would give it a try. I have a DLE 170 in my 40% and cannot be more happy. If it breaks, I cannot take it up the street to DA but again, 50% is worth the chance to me.
Old 01-03-2013, 09:46 PM
  #156
bananaman
bananaman's Avatar
Finally got to run the 120 in my run rig using cannisters (for the neighbours). Used the EME plugs, but will change out later. Easy to start, choke on, pumped fuel up line, flicked once and it popped, choke off, 2 flicks and it was running. Ran smooth after a warm up, it ran as low as 900 rpm. I used a balanced H/King 28x10 I had, as it was the only prop around here that wasn't drilled. I got it to 6200 and was going more but a cannister coupler was letting the cannister move so I backed off. I'm 60m above sea level. RPM taken from a RCexl tacho. The timing was also 35/36deg which I changed to 28. No issues for me so far, it runs.
Need to put it in an airframe with a better prop and fly it now. I'll probably put it into my old tug and the DA120 into a 40%Decathlon.
Old 01-04-2013, 03:14 PM
  #157
rcbill
I'm in the building stage here in Wisconsin but am anxiously waiting for more info and a video on the 120. Thanks for all you've done so far Bill
Old 01-05-2013, 11:02 PM
  #158
bananaman
bananaman's Avatar
Here is a clip of it running.
Unfortunately it is just me holding a GoPro at the same time so its not going to win an Oscar.
With the cannister secured, it got to 6500rpm and was idling at 1200.
My quick and nasty linkage was stopping it from going to max throttle (not by much), so I'll get a 29x10 or 28x12 and see how it goes.
[youtube]http://www.youtube.com/watch?v=ySs9ajOiMJI[/youtube]
Old 01-05-2013, 11:11 PM
  #159
taildragger21
My Feedback: (197)
Flew my 36% sbach with new EME 120 today. Video here.. Verticals are that of a projectile launching from a sling shot!
http://www.youtube.com/watch?v=p3NcL...ature=youtu.be
Old 01-06-2013, 08:16 AM
  #160
Cyberwolf
Cyberwolf's Avatar
Nice video Chad, I know little about the EME engines just what I have read here, but if they all run as good as that one does your on to something good.
Old 01-06-2013, 08:35 AM
  #161
taildragger21
My Feedback: (197)
Thanks!
Old 01-06-2013, 09:00 AM
  #162
RAMMJETT
RAMMJETT's Avatar
Taildragger ,what prop were you using in the vid and what rpm were you getting . thanks Roger
Old 01-06-2013, 09:06 AM
  #163
taildragger21
My Feedback: (197)
Beila 28x10 Carbon.. Not sure on RPMS as my tach was bad. I can say I noticed a difference iver my jc 120/da 100, and buddies dle 111's.. Way more power
Old 01-06-2013, 12:34 PM
  #164
closetguy
My Feedback: (13)
well i just tried the Vess 24a on my 60 today. and just as i thought i was getting the same rpm as the rest of the 60's that don't have a Bowman ring.
i got 6910 on the Vess 24a,that just shows how well the stock EME ring is sealing.john911 is getting 6900 with the stock ring,on the same prop.
Old 01-07-2013, 03:10 PM
  #165
yankphan
My Feedback: (9)
So I received my eme60 today... Mounted it on a jig and fired her up..... Oh yeah, happy camper! Thanks taildragger !
Old 01-07-2013, 03:11 PM
  #166
taildragger21
My Feedback: (197)
ORIGINAL: yankphan
Good Deal! That was some fast shipping
Old 01-22-2013, 12:59 PM
  #167
Arizona Flyer
My Feedback: (14)
Taildragger, others.... Does your EME have a Walbro carb? I eventually took mine out and flew her but could not get the top end right, only 5400 RPM max with a sputter so I gave up and sending it back to exchange it. In doing so BTW, I discovered the ones offered now have real Walbro carbs on them, where mine had EME.
I haven't given up on the motor, just the one I had. Even sputtering and only turning 5400 RPM, it pulled my 260 out of sight, much better than my DA 100.
Old 01-22-2013, 01:03 PM
  #168
taildragger21
My Feedback: (197)
ORIGINAL: Arizona Flyer
AZ flyer..
Yes all 120's should have walbro wj71's on them.. Mine performs like a hoss...
You mention sputter.. Are you sure it isn't an ignition issue..Pick-up sensor??? Sputtering can be caused from timing issues as well.. However don't give up on your 120.. Mine has been smoother and more powerfult than anything I have ran
Old 01-22-2013, 01:16 PM
  #169
Arizona Flyer
My Feedback: (14)
Thanks Taildragger. I didn't want to give all the details of what I tried because I didn't want to discourage anyone from this motor. I think I just got un-lucky, one bad engine out of 20 is not bad. So ignition, yes I tried a new one. Timing, yes reset to 28 degrees. Plugs.. funny story, thought the original issue was plugs so I swapped them out for a brand new set of iridium's. Just by accident, I found both the stock plugs and the new set had a crack in the porcelain and that was my original problem all along. This after swapping the stock rings out for Bowman, then back to stock, two ignitions, countless carb adjustments, removal, checking, rechecking, and finally because someone above said to throw in a new set of CM6s, I did that and presto she idled like a sleeping baby. I think the Chinese carb is the issue, or the stock rings that I put back in could be affecting the power but I gave up and decided to swap out motors when I found out the new ones had the Walbro (you just can't beat the WJ71 so why mess with the stock carb right?).
I saw your video, very nice sir. I like the field you are at too, jealous. I believe the next round will be a bolt and go and then I will make some video myself.
Old 01-22-2013, 01:23 PM
  #170
taildragger21
My Feedback: (197)
Good deal.. Sorry for all your troubles and yes it seems very isolated.I think the new one will be a charm
Sounds like MHRC took care of you..
Thanks about the flying site we that is one of 2 we have and the other is 800' of pavement.. We are lucky. Just wish the weather didn't stink..
Old 01-22-2013, 01:43 PM
  #171
BarracudaHockey
Got the 120 today, thanks for the lightning fast shipping Chad!
I've already got the GT-80 pulled from the Pawnee and am working on getting the EME fitted. It's actually about 1 1/4" shorter than the Zenoha.
When I'm done I'll be towing up other tow planes though (insert Tim the Toolman grunt here!)
I have more video of the 60 in action as soon as I get a chance to get it loaded I'll post some links.
Old 01-22-2013, 01:46 PM
  #172
Arizona Flyer
My Feedback: (14)
@ Baracuda - Going from a GT 80 to EME 120, certainly worthy of a good Tim the Toolman grunt. You should be able to pull around some full scale with that set up!
@ Taildragger - Yeah man, MHRC is awesome.
Old 01-22-2013, 02:20 PM
  #173
TimBle
ORIGINAL: taildragger21
Forgive my critism but your analogy does not do the performance justice. Projectiles launched from slingshots slow down, stop and then fall on your had.
That EME flies that Sbach to heaven like a home sick angel
Old 01-22-2013, 02:50 PM
  #174
taildragger21
My Feedback: (197)
ORIGINAL: TimBle
HAHA LOL.. Better analogy it is
Old 01-30-2013, 01:48 PM
  #175
BarracudaHockey
Here's the 60 yanking around a 91" EF Extra
[youtube]http://www.youtube.com/watch?v=WW5Fb550EVM[/youtube]
