Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Reload this Page >
DLE 20 Bent Crank - What Puller to Use for the Hub?
Old 07-04-2012, 07:53 AM
SpinnerRow
SpinnerRow's Avatar
Default DLE 20 Bent Crank - What Puller to Use for the Hub?
Crashed a plane over the weekend and bent the crank on one of my DLE 20s. What kind of puller do you guys use to get the hub off?
Old 07-04-2012, 09:42 AM
w8ye
My Feedback: (16)
w8ye's Avatar
Default RE: DLE 20 Bent Crank - What Puller to Use for the Hub?
Just use a bearing separator to clamp behind the hub to have something to clamp onto with a puller. Don't loose the key.
Old 07-06-2012, 09:53 AM
raptureboy
raptureboy's Avatar
You can clamp the hub in a vise and heat with your heat gun, then hit the end of the crank with a hammer and drive it out. Thats howI did mine, no special tools needed.
Old 07-06-2012, 11:05 AM
w8ye
My Feedback: (16)
w8ye's Avatar
That sounds very destructive?
In the case of a bent crank, it probably wasn't any good anyway, if in fact yours was bent? If it was a good crank, it wasn't any good anymore unless you put a nut over the end of the threads and hit the nut?
What about the vice marks on the hub?
