Gas Tank Setup?
My Feedback: (48)
MI
ORIGINAL: BOLTMAN
What is everyone using for the clunk line inside their gas tanks?
Tygon goes hard after time submerged in gas & I am wondering if this will cause problems in a IMAC type model? Or should I be using something else?
The ethanol in today's gas seems to be causing the problem. Either change it out every year or so or use Viton, which seems to work with all fuels. Viton can be bought from McMaster carr for one. Good luck.
My Feedback: (13)
OR
Tygon seems to harden when it's been in gas then dried out, I try to leave just a little fuel in my planes and I've had the same piece for 2 years in one of my planes and it still clunks around fine. By just a little bit I mean I have a Sullivan tank and I just leave gas in the little front part as I store the plane on it's nose (any more and it seeps through the Dubro stopper or gets through the vent line) since I store them in a tiny bedroom that's also my office
My Feedback: (53)
ORIGINAL: tande
Over here, if you want the best.....this http://www.mcmaster.com/#viton-fluor...tubing/=ik5d10 is what we use....
ORIGINAL: BOLTMAN
Which size do you usally use?
Chris923
Hey Boltman,
for the clunk I use ryobi fuel line it's opaque grey, after two years it's still perfectly flexible. It's very dear so I use tygon for everything else
You can get it from mower shops, they also sell felt filter clunks which are great.
ORIGINAL: 3136
Hey Boltman,
Hey Boltman,
ORIGINAL: 3136
forgot to mention, I keep my tanks full when stored, it seems to keep the lines soft.
No need to keep any fuel in the tank to keep this formulation supple. My original experimental tank is still in service 3 years and running, without any issues. I use the 1/8" x 3/16" size and it is the most flexible stuff I've found (including viton in 1/8x1/4 size). It is about 1/10 the cost of viton but that's minor issue since one only uses a couple feet to plumb the gas supply. You have two viable options
Hey boltman, you can get viton from Perth they also sell on ebay
http://www.ebay.com.au/itm/Viton-Rub...item2314e5011d
ORIGINAL: 3136
Now you have made it really easy! Thanks, I will order some there.
Cheers
Cheers
[/quote]
+2 to that, I will be ordering some my self. Thanks for making it easy to find.
Cheers
ON, CANADA
Or you just go with a Rotoflow tank and never have a worry of this again.
See link below. Handful of people at my field using them with glow or gas and no worries.
Check it out.
http://www.jlproducts.net/ProductRotoFlow.html
I have had mine now for the season and Model Airplane News just did a review on them. Fantastic.
Steve
Check it out.
Steve
Is the Poly line like the kind they use in Hospitals for IV lines? Thanks
ORIGINAL: FullSpool
I use my poly line that I carry, works great and doesn't stiffen up like tygon. For the Clunk I really like walbro clunks.
<br type="_moz" />
<br type="_moz" />
My Feedback: (12)
It's different as most hospital stuff is nitrogen/air rated. <div>
</div><div>All info can be found here. http://www.vital-rc.com/fuel-line.html if you're interested. I buy all my viton from McCaster as it's another</div><div>reliable source. </div><div>
</div>
</div>
I cap my vent with a fuel dot, and use a fuel dot for the fill line, so I can leave gas in the tank and not have it leak or stink. Should keep the lines flexible for quite some time.
Cap'n, you probably should not use the med tubing. Looks nice but I think you would find the material falling apart after a few months. It's primary use is saline delivery or air delivery
ORIGINAL: MTK
ORIGINAL: captinjohn
I used new Hayes neopreme line in the gas fuel tank and it did not last a week. The rest of the line I use on a hand crank gas pump....works fine for that because the fuel is not in it only when using the pump. Capt,n
Cap, you may want to check the fittings of your hand crank pump. I suspect you will find stress cracks on the neoprene tubing. Let me suggest that you buy yourself a roll of the PolyU from Mc Master Carr. You won't be disappointed.....Inside the tank or out, makes no difference....
