Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 Engine question please!!!!!!!!!!!!!! >
Old 12-11-2012 | 01:10 PM
My Feedback: (139)
Default Engine question please!!!!!!!!!!!!!!
I have a hangar 9 piper cub 1/4 scale and will like to know sugestions on gas engines wich are new for me,this will be my first gas engine; so question is:
DLE 20 or zenoa 20?
Or im open to recomendations,maybe diferent brands or size?
Thanks.
Here are the manufacturer plane specs:
Product Specifications
Wingspan: 106 in (269 cm)
Overall Length: 68 in (172.7 cm)
Wing Area: 1630 sq in (150.2 sq dm)
Flying Weight: 14.5–16.5 lb (6.6–7.5 kg)
Engine Size: 1.00–1.60 2-stroke; 1.20–1.80 4-stroke; 20–26cc gas
Motor Size: E-flite Power 110 Brushless Outrunner
Radio: 4 to 6 channels
Servos: 6 JR Hi-Torque (JRPS821) digital servos
Trim Scheme Colors: Cub Yellow (HANU884) & Black (HANU874)
CG (center of gravity): 4.0 to 4.75 inches from the leading edge of the wing at fuselage
Wing Loading: 21.73 oz/sq ft
Prop Size: 15x8–16x6 for gas; 14x6–16x4 for 2-stroke; 16x6–18x6 for 4-stroke; 19x8E for electric
Spinner Size: 8mm x 1.25
Recommended Battery: 4S 4000 - 5000mAh Li-Po, 2 required for electric conversion
Aileron: 5/8 in—up; 1/2 in—down
Elevator: 7/8 in—up/down
Rudder: 1 ½ in—left/right
Scale: 25%
Needed to Complete
Old 12-11-2012 | 01:18 PM
ggraham500's Avatar
Default RE: Engine question please!!!!!!!!!!!!!!
If more scale-like flying preferred then the Zenoah. Either will do a great job. A Saito FA-125 would also be interesting.
Old 12-11-2012 | 01:59 PM
How about a DLE 30? Simple, reliable and powerful.
Old 12-11-2012 | 02:05 PM
My Feedback: (19)
The DLE30 or similar engines are also an excellent fit in this airplane.
Old 12-11-2012 | 02:08 PM
The DLE20 can be rail mounted, and will likely hide inside the cowl best, but I'm with Truck...have some fun with the 30 There are also lots of airframes out there that are appropriate for the 30, for when its time to move your equipment from the cub into something else...
Old 12-11-2012 | 05:38 PM
My first thought was a 30 too. You should see one of those fly in the hands of a decent 3D pilot! Realizing that's not going to be appreciated by many that think of a Cub in more sedate terms, I don't know how you could go wrong with the DLE20. Wild or mild, your call....
There's only about 8 oz. and 2" of prop difference in those 2 engines. Nobody could say you were wrong going either route?
Old 12-11-2012 | 05:53 PM
My Feedback: (19)
The DLE 20 has plenty of power for the CUB .... any way you look at it. I prefer the 30 because it sounds a bit less like a glo engine .... less of the 2 stroke sound ... especially if you keep the thing throttled back for scale like flight. But when you need it, you won't have any problem climbing to altitude with the 30!
Old 12-11-2012 | 06:47 PM
Go on YouTube and watch some video,s of them. I like the sound of a 4 stroke engine the best in a cub. If you look for good used engines you can have a 4 stroke & a 2 stroke. A 30 DLE can be found fairly cheap...for later on a more zippy airplane. Just my 2 cents........Capt,n
