OPS Maxi Conversion
Has anyone got a cached copy of the original article/ thread as all the links are dead now. Such as (http://tech.flygsw.org/OPS.htm )
Thanks in advance for any leads etc!!
I could find that exact match but hope this helps
http://web.archive.org/web/*/http://tech.flygsw.org/*
Thanks Mark, its a good start. There is another article that i read a few years ago which went into more detail which i shall continue to search for.
Thanks again for your help.
WY
FWIW The OPS is well made but has a few odd bits. The orginal Delorto carb should be considered a paper weight. The 30 is a stroker, so a ST 3000 will out turn it on an 18" prop. But on a 20" prop the OPS wins.
