ROTO 85cc inline 4 stroke
Old 10-14-2013 | 12:22 AM
SJN
Default ROTO 85cc inline 4 stroke
Just found this..... Looks neat
http://www.rotomotor.cz/rotomotor/es...36-ROTO-85-FSI
Coming soon
Basic technical data:
* DISPLACEMENT 85 ccm
* BORE 39,5 mm
* WEIGHT 3 000 g
* PISTON ROD 4 × NEEDLE BEARING
* CRANK SHAFT 4 x BALL BEARING NSK
* INGNITION PROCESSOR ROTO
* FUELGAS + OIL MOTUL 710 1:40
* RPM 1000 - 5800
* 2 BLADE PROPELLER 25-26/10-12
* 3 BLADE PROPELLER 24/10-12
* STATIC EN. THRUST 13 kg
Manufacturing technology ROTO 85 FSI
  • Crank case (kit) – it is rough-worked of the cast at the CNC milling cutter. After that it is covered or slashed with a special colour.
  • Cylinder (roll) – it is made of one piece of dural with pressed insole from the mild-granular cast iron, it is sharpened and honed to the correct size.
  • Piston – it is casted from silicon alloy with one sealing circle. The aparature for the bung 8 mm is honed.
  • Piston rod – it is forging, which is completely worked. Two needle focuses are moulded into piston rod, it is made for the piston and cranked bung.
  • Crank shaft – it is made of one piece of steel, it is cemented and hardened and it is completely sharpened.
  • Back lid of the engine – it is worked casting, in which is hardened and sharpened rolled slide - valve layed.
http://www.youtube.com/watch?v=eJ7mhIPcNY8
Old 10-14-2013 | 03:18 AM
earlwb's Avatar
That is a pretty awesome looking engine. Sounds pretty good too. Putting the carb at the rear also keeps the engine a lot more narrow in profile too. I wonder if they'll make a inline three cylinder version or not. I remember the Kolm 3 cylinder engine sounded very realistic when flying around in an airplane.
Old 10-15-2013 | 05:24 PM
My Feedback: (66)
I wonder if they are coming out with a replacment for their 35cc single. most MFGs just use cylinders they have already when doing stuff like this. Roto has a 35cc single so two of these would make a 70. So did they make a larger bore to make up the extra 15cc?
never mind I see they make a 85cc opposed twin. lol i was hoping for a 42.5 cc single to compete with the OS 40FS
Old 05-19-2014 | 12:43 PM
affas's Avatar
The new modified Roto 85 FSI inline are approaching me fast :-)
New and a lot better fuel distribution seems to solve bad midrange and also tricky adjustment. I will post testrun both mounted on ground and inflight test in my old Carden Yak before I will mount this beatiful engine in my Top Flite P47 Razorback
Old 05-21-2014 | 09:40 AM
My Feedback: (43)
They have an inline 130 shown on their website. It does not have any data, so I guess it is in the works.
Old 05-21-2014 | 10:32 AM
SJN
The 130 3 cylinder looks very cool.....would power my CY model / easytiger spitfire well. :-)
The 85cc might be a bit small for a quarter scale spitfire.... The price seems good, hope the 3 cylinder 130 is affordable.
Old 06-19-2014 | 05:47 AM
affas's Avatar
https://www.youtube.com/watch?feature=player_detailpage&v=PUlX30EoNv8
Old 06-19-2014 | 07:41 AM
My Feedback: (86)
I've been thinking about this engine for an Aeroworks P-51. Has anyone else tried this or done any research about how the two might fit together?!?!?
Old 06-19-2014 | 06:14 PM
My Feedback: (8)
Considered one myself for a top flight p40.... I have been running of the opposing twin for over a year now with great success I am very happy with the engine
Old 06-19-2014 | 06:18 PM
My Feedback: (8)
So much for doing things on an iPhone....
Old 07-17-2014 | 02:39 PM
affas's Avatar
http://youtu.be/8ZSYAhFCbXc
Old 07-17-2014 | 06:52 PM
My Feedback: (8)
It sounded real good what prop did you run?
Old 07-17-2014 | 11:42 PM
affas's Avatar
The propeller is 25x12 Xoar
Old 07-18-2014 | 09:27 AM
My Feedback: (8)
Here are my prop numbers
25x10 XOAR 5740 rpm
22x14 XOAR 6050 rpm
i also have run the 24x12 but have not tached it yet .... I'm going to try a 23x12 next and hope that it will get the speed I'm looking for. The 25x10 seemed to be the best for speed so far. I was actually dissapoonted with the 22x14 ... Not sure why it didn't deliver the speed I hoped for. If you haven't tried the 25x10 yet I would think it would be great on your yak
