Zenoah G62 ei conversion?
Old 12-06-2013, 02:22 PM
rltrahan
My Feedback: (128)
Default Zenoah G62 ei conversion?
Does anyone recognize this G62 conversion? I tried to find Cunningham, Bennett conversion pics of zenoah g62 engines and none look like this one. Engine was bought from estate sale with no information on it. Trying to figure out how old this conversion is and what voltage of battery I should use. Im figuring 4.8 nicad but want to make sure before hooking it up.
Russ
ID:	1945363   Click image for larger version
ID:	1945364   Click image for larger version
Old 12-06-2013, 02:38 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Looks like a early Ralph Cunningham conversion sporting a Spehar muffler
Later Cunningham G62's had the electronics in a Bennett style cup. They also have the carb mounted closer to the head and turned so the throttle will be a straight pull. The later ones had a external pulse line.
Spehar mufflers went out of business but a Chinese company now makes a knockoff listed on the bay.
Old 12-06-2013, 03:57 PM
rltrahan
My Feedback: (128)
W8YE, thank you for the info. Im putting this in a yellow ac p-47 and want to make sure I set it up right!
Old 12-06-2013, 06:40 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Don't try to start it with the throttle open very far as the timing will be advanced and it will kick back.
Old 12-09-2013, 06:13 PM
tkg
Dat be a G-62 with an early CH Electronics Module mount. The only thing missing would be a Bosch Cap. CH used this design for years, Later ones had a fixed timing ring with a Syncro Spark added for timing.
Locking the timing ring is easy so is adding a SS.
Old 01-01-2014, 12:01 AM
Octopus RC
RCEXL have a conversion Kit for Zenoah 62 as well , contact us if you need one .
