Dle 30 side carb
FL
Due to cowl size and shape I have purchased a DLE 30 side mount carb to use on my latest plane. I have heard that these engines have been noted for not running to well.
I noticed this engine has a Tilitson carb on it and wondered if anyone had thoughts on changing it to a Walbro carb. I have been told to mount the engine at a 20 deg angle and that would also help with this engines supposed problems. Any comments are welcome.
Herb
Herb
My Feedback: (19)
Some people loved them, some hated them. I believe the fuel pooling problem was real and quality control on those early DLE engines wasn't the best. You might want to read through some of the old threads about that engine. It wouldn't be my first choice if I needed a shorter engine though I love the later rear intake 30.
FL
Thank you both for the input. Lifer is there anything special that you did to the engine, like mounting it 20 deg of angle that some have suggested. Are you using the tilitson carb or something else.
Thanks for the info.
Herb
Herb
