Need help identifying mystery twin?
I recently purchased a 30% Carden Cap 232 with 70cc twin yesterday and am trying to identify the engine. The man I bought it from said it was a custom built Sachs 4.2cc and that was about all he knew. I have taken a few photos of the engine, and tried to identify it from Internet photos. So far, the only photos I have found which look similar to the engine I have is of the D&B engines by Ridge Machine. Though, the only engines they list are a 3.7ci (61cc) and a 5.1ci (83cc). The prop on the aircraft is a Mejzlik 24x10, about right for a 70cc I think? Can anyone help to identify this engine?
The only markings I could see on it anywhere was a small series at the base of the cylinder heads, "RO28131 150"
Thank you for your help!
Thank you for the replies, are Spehar engines the same as SPE engines? Found an SPE 75cc for sale a while back, looked exactly like this one. Can anyone tell me the rpm range, recommended prop (it has a Mejzlik 24x10 on it now) and gas/oil mix?
Thanks!
Thanks!
Should be a good motor if crank hasen't slipped.
BCCHI. Tired old C&H guy.
Thank you for your help, is the ignition something that should be upgraded? Hadn't even thought about that yet! Did some more digging on the web, found this thread and I believe the aircraft/engine there is the one I now own. Looks exactly like the plane and engine I have!
http://www.flyinggiants.com/forums/s...ad.php?t=88641
