DA/DLE Ignition Systems
Old 10-19-2015 | 07:38 AM
Sonny.C's Avatar
My Feedback: (23)
Default DA/DLE Ignition Systems
Hello All,
I have a question regarding the DA ignitions vs DLE/EME/XYZ ect.. ignition boxes.
I've heard DA engines with DA hall sensors must have DA ignitions. Is this true?
Can you use a generic RC_Excell Ignition box on a DA if the hall sensor is replaced?
I did discover that an ignition box from a DA 60 works fine on a DA 85 because I successfully tried it this past weekend.
Thanks!
Sonny
Old 10-19-2015 | 07:42 AM
w8ye's Avatar
My Feedback: (16)
People generally let DA repair their engines. Correct, the DA ignition is different from the CH and RCEXL style ignitions
But yes, you can put a CH or RCEXL style complete ignition on your DA and it will run just fine.
Old 10-19-2015 | 08:13 AM
My Feedback: (19)
The sensor on a DA engine is a coil of wire where most other ignitions use a Hall sensor. Both systems work well, they're just different and will not interchange.
Old 10-19-2015 | 10:50 AM
kmeyers's Avatar
Those answers are correct.
I will add the hall sensor (C&H Rcxel & others type) is a switch (on & off), and the coil ( DA type) is a inductance reading a voltage change as the magnet passes
TMI ?
Old 10-19-2015 | 08:02 PM
w8ye's Avatar
My Feedback: (16)
Converting a DA50 to CH Ignition
https://www.youtube.com/watch?v=oa5VsPcDZK4
Old 10-21-2015 | 04:04 AM
Sonny.C's Avatar
My Feedback: (23)
Thanks for the feedback!
