DLE35RA Can I use a 6.6 volt life batt with no regulator?
This will be my 1st gas plane for the end of next summer I hope.
Aeroworks 30cc Edge 540
I want this setup as simple as I can do it.
I want to use a 6.6 volt life battery without a voltage regulator for
the ignition on a DLE35RA.
Does anyone have this setup and how well does it work?
Jimmy
Jimmy
My Feedback: (7)
Has anyone suggested to instal an IBEC from Tech-Aero, It will give you the option to adjust the voltage for the ignition and it will give you the means to kill the engine via a switch using the radio.
http://www.tech-aero.net/ultra-ibec
My Feedback: (19)
Good suggestion on the IBEC though. I use them on most of my planes. Excellent product.
