Zenoah G26EI spinner Q????
VA
I've got a Great Planes 4" spinner I'd like to use on my G26EI.......what's the easiest way to go about doing this? The spinner of course has a place in the exact center (tip) for a single bolt to be used. I'm hoping an adapter/coupler from our local hardware can be used. Thoughts/tips??
Thanks!
Thanks!
My Feedback: (19)
Adapter nuts should be available from either Great Planes, TruTurn or Vortec to mate the spinner to the engine. Go to the Tower Hobbies site and check under those brands as they carry all three. You may have to find the thread size of your crankshaft and some of the listings will be by engine size and brand. The TruTurn website may be another good source for info. All of these spinner brands retain the spinner cone using the same 10-32 SAE threaded bolt size. Vortec spinners are made by Dave Brown so you might find them under that name.
