Dle 20 crankshaft bearings
I have a Dle 20 which runs well but the sound when idling has got a bit noisier, presume the crankshaft bearings are wearing. I notice the same size bearings are available on alixpress for a fraction of the cost of actual dle bearings, Has anyone tried these?
I have had an excellent experience buying from Boca Bearings when I needed to replace bearings in my 30+ plus year old Enya. They have bearings for most RC engines, including the DLE 20cc. You select the engine and they say which bearings will fit it. They have already done the matching/pairing homework for you. Try this URL
https://www.bocabearings.com/product...mFeatures=20CC
If that does not work, just google Boca Bearings and go through their web site. They offer a range of bearings from standard to ceramic. The standard two bearing set #ENK176 is $13.64.
Attachment 2272615
Attachment 2272615
IL
In the past all my gas engines that became noisey and slappy, the cause was the two connecting rod bearings (easy to check the rock at tdc).
Just another possibility. There are 4 bearings, 2 crank and 2 connecting rod.
Sorry, I didn't think about customs... I was thinking of quality. I know the bearings I bought from Boca Bearings are very good quality... I don't know about Alixpress. I've heard they are a slow boat from China.
My Feedback: (19)
I’ve rarely seen main bearing failures though it was more common in early production engines. Rod bearing failure is far more common and the wrist pin bearing seems to fail more often than the one on the crankpin. Crash damage changes all the rules. Have you had any prop
strikes or crashes?
Not on Dle's but I've had those roller pin bearing fail on crrc engines in the past. The engine is coming up on 50hrs running so I suppose I should change them out anyway. They can make an awful mess if they come apart during operation. Do the main crank bearings show any symptoms before failing?
My Feedback: (19)
