DA 100
Old 12-26-2003 | 07:03 PM
Default DA 100
This is for the DA guys. What kind of rpm's are you getting on MSC 26X10? Any info would be appreciated.
Old 12-26-2003 | 07:16 PM
rmh's Avatar
rmh
Default RE: DA 100
local users typically get low to mid 6000 rpm on that specific setup on stock mufflers -
Do not squeeze the needle trying fo some magic number - if the engine is new -
(these are three seperate users)
Old 12-26-2003 | 08:32 PM
JohnVH's Avatar
My Feedback: (38)
Default RE: DA 100
Everyone I know is running 28x10's, one guy is running a 27x10 I believe. With a Mezjlick 28x10 about 6500 I think is right.
Old 12-27-2003 | 07:07 AM
My Feedback: (20)
Default RE: DA 100
With Amsoil 100-1 and Mejzlik 27x10 I'm getting 6300 RPM. Last checked 11-23-03
Old 12-27-2003 | 08:07 AM
rmh's Avatar
rmh
Default RE: DA 100
Has anyone else noted that the Mejzlic 28x10 and 27x10 --are about the load on an engine?
Strange -but they seem to have shifted effective pitch for more disc area -
Actually not a bad trick - as some models like more disc area.
I use bigger props on smaller -lighter models - then the engine can still "jump" .
A Bambula 26x10 loads about the same - on the ground but on alight plane really cranks in the air.
They sent a new prop design which I test ran and noted it was 400-500 under a MenzS same size
Their comment was - "we do not design prop for static rpm - but for in flight performance ".
They do have a point -
Old 12-27-2003 | 08:21 AM
Default RE: DA 100
A buddy of mine gets 6200 6300 on that setup..............In a H9 extra no less...............puts white caps in my coffee!!!!!!
Old 12-27-2003 | 10:48 AM
Default RE: DA 100
Yes DH, I also have observed that the Mejzlik 27x10 and 28x10 are about the same load. I've been running the 27x10 for several years on a 3W-100 in a 33% Edge. Performance is excellent despite a heavy airframe (29 lb). Friends who run the 28x10 prop, get about the same static rpm with the 3W-100. I would imagine that the 28 inch prop has more flywheel effect, but that's just a guess. I wouldn't use either of these props for 3D, but they're great for sequence flying.
Old 12-27-2003 | 11:29 AM
JLB
Default RE: DA 100
And what would you use for 3D on a 26-28# plane with 100cc engine ?
Old 12-27-2003 | 12:57 PM
rmh's Avatar
rmh
Default RE: DA 100
A SWAG--- probably start with some 26x10 stuff -
This size is not to small for any 100 class engine -if you are doing 3D stuff where the engine really neva gets a chance to unload .
it also keeps em from going up in smoke from simply being overpropped.
(Now some one will bring up their XXXX engine which sheds blades on anything under a 30 x10 --)
Old 12-27-2003 | 05:48 PM
Default RE: DA 100
If it's a 3W or DA-100, I'd use a Menz-S 27x10 for 3D. Great pull, and quick acceleration because it's a light wood prop. The prop can be noisy in straight and level flight if you let it unload and rip. This prop will turn 6400-6700 rpm static on these engines.
Default Where's the delete key?
Old 12-27-2003 | 11:22 PM
Default RE: DA 100
Just wanna say thanks to every one who responded.
Old 12-28-2003 | 07:49 AM
My Feedback: (20)
Default RE: DA 100
ORIGINAL: Diablo-RCU
I keep hearing about the Menz-s but have not tried one yet. Guess I need to get of my butt and order me one.
Old 12-28-2003 | 08:30 AM
rmh's Avatar
rmh
Default RE: DA 100
The 27x10 -on the 100DA tops out at the 6400 figure at our 4500 ft elevation - but still a very good combo-
for ONLY 3D stuff - you might prefer to reshape the prop for a few hundred more revs -
Old 12-28-2003 | 11:01 AM
0tter's Avatar
My Feedback: (39)
Default RE: DA 100
I agree, I have been flying with 27-10 now. The 3W and Menz work well. I have tried the NX, but not quite as much pull. The NX 28-10 works pretty good for 3D stuff.
Old 12-28-2003 | 12:03 PM
JohnVH's Avatar
My Feedback: (38)
Default RE: DA 100
Doug, on my zdz80 powered sukhoi I went from a ProZinger 26x10 to a Menz S 26x10, difference was noticable to people watching!! Im never buying another prozinger!
