BME 44 Sensor Moved?
Old 02-14-2004 | 08:46 PM
GoeKeli's Avatar
My Feedback: (18)
Default BME 44 Sensor Moved?
I have an older BME44 that has given me great service until recently. It started to sputter sometimes and I though I had old gas or the weather had changed ect then today it would not run after flying about 8 flights. I topped off the battery then tried again. Got it home and got the cowl off the looked around. The pickup sensor looked like it was cocked in about a centimeter, it was not loose but just moved over. I loosened it then put it even with the crankcase like it used to be, and tried to restart it. After quite a few flips it started and I began re-tuning the high and low. Something strange, when I jab the throttle up it sometimes pops or stumbles with the low needle pretty darn lean. Do I need to do anything? Any help would be great. I owe a lot to this engine and plane combo, it has performed excellent and I have learned some much having a stable platform.
Joe
Old 02-15-2004 | 08:38 AM
My Feedback: (16)
Default RE: BME 44 Sensor Moved?
Make sure the sensor is far enough over the magnet but other than that, there is really no adjustments.
Old 02-15-2004 | 11:41 AM
GoeKeli's Avatar
My Feedback: (18)
I think that I will put some blue locktite on it. Yes I agree with you, it should be over the sensor and centered.
Joe
Old 02-15-2004 | 12:17 PM
My Feedback: (31)
Is there any physical damage to the Hall Effect sensor? Did it rub on something when it moved? Rumor has it these sensors will act as described when in a failure mode. The sensors are inexpensive, you might consider replacing it...
Is there a gap between the sensor and the timing ring or magnet? The gap should be about the thickness of matchbook on business card.
Old 02-15-2004 | 06:52 PM
GoeKeli's Avatar
My Feedback: (18)
Thanks for you reply Michael. No damage that I can see and it did not come in contact with anything. I will check the gap. I might have a chance to go to the field tomorrow and fire it up. I do remember reading somewhere about sensors failing. It ran quite good yesterday after I re-centered the sensor and tightened it down. Also used some loctite on the threads. Where would I get a new sensor? RCI?
Joe !~)
Old 02-15-2004 | 07:44 PM
My Feedback: (31)
Ralph, C&H Ignition or BME would have them. There about $10.00...
Old 02-15-2004 | 07:59 PM
My Feedback: (16)
Make sure that the sensor is over the magnet.
I had problems a couple of years ago and purchased a sensor just to find out that my adjustment was wrong.
Old 02-15-2004 | 08:52 PM
GoeKeli's Avatar
My Feedback: (18)
Oh man! That is a cheap part here in the land of the big buck toys! I will check again tomorrow that the sensor is right over the magnet and if I still have problems I will order a replacement. I'll let you know how it goes.
Joe
Old 02-16-2004 | 05:31 PM
GoeKeli's Avatar
My Feedback: (18)
It runs great now! That little bugger really caused me some greif and a sore right arm~~! I put some blue lock tite on the threads before it went back together and it seems perfect now. I was really worried. Thanks again for the help guys!!
Happy flyin,
Joe
Old 02-16-2004 | 09:28 PM
My Feedback: (16)
Sounds like it all worked out in the end!
Old 02-16-2004 | 11:25 PM
GoeKeli's Avatar
My Feedback: (18)
It sure did Geistware, that little staudacher is a rocket again. I almost wanted to put the 20-10 on just to really rip it up. Weird how something that small had so much to do with a real headache. Thanks for your help!)
JK
