Do I need a Bosch Cap?
Old 03-21-2004 | 11:49 PM
Bass1's Avatar
Default Do I need a Bosch Cap?
Hi people, I have a used Brison 3.2 (Blue case) that I just purchased. I have a couple of questions. The spark plug cap is rubber with the ground wire secured to the base of the plug with an automotive type clamp.The ignition wire wire is wrapped with electrical tape from the module to the cap. Is this the standard or do I need the Bosch type cap that I'm seeing lately? If so, where do I get one and Can I install it myself? Also, Coming out of the ignition module is a short 3 wire lead going to a male 3 pin plug that plugs into a two way 3 pin female adaptor which in turn connects to a 3 pin male plug going to the sensor. This seems like alot of connectors to possibly vibrate loose. How do I secure these connectors? Any help would be appreciated. Thanks Ben[sm=confused.gif]
Old 03-22-2004 | 02:35 AM
Antique's Avatar
Default RE: Do I need a Bosch Cap?
I have flown gassers for about 17 years, never had to put a Bosch cap on any of them..Zenoahs of ALL sizes, Quadras, and a few others..My radio is a 1972 ProLine AM converted to a MicroPro 8000 many years ago...The Dean's plugs usually don't come apart, but a piece of vinyl tape or heat shrink will be good insurance..
Bosch caps come from C&H....You can put it on yourself, it just screws onto the end of the spark plug wire and the ground strap is soldered to the Bosch outer shell...
Old 03-22-2004 | 06:40 AM
My Feedback: (16)
I agree with RCIGN1, it is not necessary.
I put one on because I have had the ground straps break.
Old 03-22-2004 | 10:07 AM
Antique's Avatar
I should have said that most of mine had my ignition inside the mount or were not converted..The coil on a magneto engine is grounded through one of the spark coil screws, and has no ground strap..Most of the engines with a Bosch cap have a braided shield surrounding the spark plug wire and soldered to the metal shell..Only way one of those can break is if the cap falls off the spark plug, so the engine dies and the interference stops anyway....
Old 03-22-2004 | 02:09 PM
Bass1's Avatar
Thanks for the info! Is the electrical tape there for any reason??
Old 03-22-2004 | 06:49 PM
My Feedback: (16)
OK, I will bite, what electrical tape?????
ORIGINAL: Bass1
Old 03-22-2004 | 07:21 PM
mstroh3961's Avatar
ORIGINAL: Bass1
Old 03-22-2004 | 07:25 PM
Antique's Avatar
Nobody that makes ignition uses electrical tape, must have been from the former owner...
Old 03-22-2004 | 08:12 PM
Bass1's Avatar
I wonder why he wrapped the wire in electrical tape? I guess I'd better unwrap it to see if something is hiding under there![X(]
Old 03-22-2004 | 08:22 PM
mstroh3961's Avatar
might have been to keep it from rubbing on the cowl.....if it had one....[sm=biggrin.gif]
