G26 throttle
Old 05-13-2004 | 12:02 AM
4 stroken ron's Avatar
My Feedback: (29)
Default G26 throttle
Does the G26 use a straight on throttle push rod or does it have to use a bell crank?
Thanks for any help.
Ron
Old 05-13-2004 | 12:35 AM
Default RE: G26 throttle
You have to install a bellcrank. Good engine, but the throttle set up could have been improved when they upgraded the engine.
Old 05-13-2004 | 05:38 AM
My Feedback: (18)
I did not use a bellcrank on my instillation, Just installed a 1/16 ball link and nylon rod. Make sure you read the instructions on what is right end up on the carb and there should be no problems.
Old 05-13-2004 | 02:32 PM
You have your choice. G26 ships with carb block that rotates the carb to allow a straight shot for a throttle linkage, as well as the original if you want to use a bellcrank.
Tim
