Bent Shaft!!!
well now ive been told-maybe the crank got bent wile being shiped back to me,the engine took me a wile to reinstal it will take me wile to take the engine back out.well maybe the south texas heet just melted it crooked.
My Feedback: (23)
#31
ORIGINAL: Herby 1
Don't know, haven't seen the alleged bent engine yet
BCCHI.
#32
ORIGINAL: bcchi
Maybe this is the same guy that told us there was no way he could find TDC on his engine because his engine was inverted. May he could find bottom dead center.
BCCHI.
ORIGINAL: Herby 1
BCCHI.
#33
I dont know but I am verry mixed up here. on this post is some one mad at Ralph because of a bad job???
I though Ralph had a second nick name as "herby" last time he desided he wasent going to post no more here on RCU.
Well from y experience ralph is a great guy to deal with, does great work and is on time. and also Backs up his work and words.
#34
Ralph is not only a great person to deal with but is a real stand up guy who takes pride in his work which shows in his excellent workmanship, and offers a lifetime warranty on it which includes crash damage. It does not get much better than that, if ever.
Karol
Karol
#35
My Feedback: (9)
WA
I sent my 3W-50 to Ralph with a lot of crash damage: bent crank, broken cylinder head, broken carb block, etc.. He sent it back and you would not know it had been crashed. He works wonders, and his prices are surprisingly low. If I ever damage another gasser it will go to Ralph. I found a good way to get in touch with him was to join his engine forum and send him a PM or just post your question. He gets right back to you, unless he's out for a while racing or something.
Sam
Sam
#38
IL
While flying my Ziroli P40 the dowel pin in front of the wing failed causing the wing to tear away during a four point roll. The result was a fuselage which became a giant lawn dart. I sent the G62, which had a bent crank, to Ralph at RC ignitions, we got the motor back before the airframe was repaired, Ralph straightened the crankshaft, replaced the hub and test ran the engine for a Very reasonable price. When we finally did get the airframe finished (Nov 1,2008) the engine swung a 22/10 at 6900 rpm. His price for repair and quality of workmanship is one of the better values in the hobby. Kudos to Ralph!
Jerry
AMA1697
Jerry
AMA1697
#39
I took four engines at the same time to Ralph last year for some research work. None of the four had been involved in an incidident that would have bent the crank. In checking various things on the engines we noted that all four had more than .004" of shaft runout. By the time he was done, which was a very short time later, the worst one had been corrected to .002" and two had been corrcted to .001". The last one was a little less than .002". Those are still among the straightest cranks I have to work with. Much better than factory standards.
