Precision Eagle Parts
Old 07-20-2004 | 07:15 PM
My Feedback: (51)
Default Precision Eagle Parts
Hi,
I am looking for parts for a precision Eagle 4.2 Glow Engine, I need the cylinder. Does some one know where I can find one? It is diffrent than any sach dolmar cylinder so I am looking for a precise sourse that can help me out on this search.
Old 07-20-2004 | 07:24 PM
tkg
Default RE: Precision Eagle Parts
It is a Sachs 4.2 cylinder, its just machined on the outside to be pretty. If you are running it on glow then there will be an adapter in the cylinder to make the spark plug hole fit a glow plug. Also some had a second glow plug installed. This would be the only mod you would have to make to a stock cylinder.
Old 07-20-2004 | 09:24 PM
Antique's Avatar
Some Precision Eagle cylinders had the transfer ports opened up at the base, and the piston was cut about 1/8 on the skirt on the intake side for more intake duration....
Sachs parts are $$$$...
Old 07-20-2004 | 10:20 PM
My Feedback: (51)
Ok but where can I find them? Any web site?
Old 07-20-2004 | 10:50 PM
Antique's Avatar
Brison, Fox, FPE, Air Hobbies, J&A, any company that sells a 4.2.....
You could do a search, Sachs was bought out by Makita...Any chainsaw dealer can find you a cylinder....
Old 07-20-2004 | 11:04 PM
My Feedback: (51)
I apreciate the help, well all the stated brands have diffrent cylinders than the PE but maybe Makita, I should see that. If in any case someone had one used cylinder or new that wanted to sell I would be happy to take it off his hands.
Old 07-20-2004 | 11:16 PM
Antique's Avatar
.ALL 4.2 stated brands use the Sachs/Makita 49ZN cylinder...TKG was correct, the cylinders are basically the same, just machined on the outside to look pretty...
NOBODY sells a 4.2 single with a different cylinder, there aren't any..PE made singles, inline twins and inline triples.. Some were glow, some ignition..Red and gold anodized cases...Brison cases are also anodized..Fox cases are polished...Some use Sachs cranks, some make their own..Sorry if you don't like the answer, It's FACT..Been looking at and repairing these for 18 years, starting with A&M and Lee Sachs conversions....
The 49 cast into the cylinder base is the bore size, 49mm..The stroke is 36mm.
Actual size is 4.1 cubic inches...The saw is a model 120 Super..
There IS a 4.2 Sachs, model 122 Super and 123..47mm bore, 40 stroke...
Specs from the Chain Saw repair manual, Intertec Publishing, 9th edition, page 452.
Old 07-20-2004 | 11:35 PM
My Feedback: (51)
I might be wrong I am just saying what I was told from my mechanic. I personaly have a Brison 3.2 and he's got this PE engine there. Since the engine had a crash in the water the cylinder broke, so he was looking for a new cylinder and he told me that he wasn't able to find one that would fit that engine. Now he knows that Sachs Dolmar Cylinders are used in all those engines, so I presumed that he knew well those cylinders. He stated that no one would fit the block. If you state that ANY one will do than I will thell him that.
I pesonaly have very little knowlege on Gas engines.
Old 07-20-2004 | 11:54 PM
Antique's Avatar
I just looked at 5 of these, there are slight differences.The closest one is on a 4.2PE with a red anodized case..The casting numbers on the base are 49ZN4 W2+ MAHLE....The cylinder extension at the base is machined flush and the transfer ports are opened straight down to the size of the hole in the crankcase...The bore and stroke is the same for all, so any cylinder you find should work...Air Hobbies used this same cylinder, I have one here....The Air Hobbies cylinder was not machined flush or ported like the PE....
Old 07-21-2004 | 08:48 AM
My Feedback: (50)
Don Kanak at Planes Plus made the PE Engines. I have several and they run great. Check out the Planes Plus website for the number and call Don or Carla. I'm sure they can help.
Old 05-23-2025 | 07:40 PM
I have aquired an Eagle 3.2 in really nice shape if anybody interested.
