DA100 Caeb setting
Old 11-23-2004 | 09:18 PM
SLINGSHOT-RCU's Avatar
Default DA100 Caeb setting
Where should the low and high end be set for first run..?
Old 11-23-2004 | 10:15 PM
Antique's Avatar
Default RE: DA100 Caeb setting
Low and High should be at 2 turns open for ANY engine ever made..You start it up, it WILL be too rich on both..You will LEARN to set your carb BEFORE you fly the plane..You WILL NOT damage the engine doing this..Its ELEMENTARY....
Set the high a little rich, then set the low for good transition, then re check the high and go fly....NOTHING TO IT, live a little ....
Old 11-23-2004 | 10:57 PM
RTK's Avatar
RTK
Do what Ralph just said.
Old 11-24-2004 | 09:28 AM
DENNIS C's Avatar
My Feedback: (99)
ORIGINAL: SLINGSHOT-RCU
Manaul states 1 3/8 low end & 1 1/2 on high end.
Old 11-25-2004 | 10:00 PM
Thanks i will start there and tune it in before flight.
