Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 us41 conversion to electronic ingition >
Old 01-16-2005 | 12:29 AM
My Feedback: (58)
Default us41 conversion to electronic ingition
what is the cost of putting electronic ignition on a US 41 engine. Also would the ignition cost more than the engine is worth. Thanks for your reply. Wayne
Old 01-16-2005 | 08:35 AM
TLH101's Avatar
My Feedback: (90)
Default RE: us41 conversion to electronic ingition
Should be able to find all the answers here: http://www.ch-ignitions.com/
Old 01-16-2005 | 02:00 PM
My Feedback: (58)
I looked at ch-ignitions and I didnt see one listed for the us-41, will any complete system work on any engine. Wayne
Old 01-16-2005 | 04:02 PM
tkg
CH Ignition....$169.95. Remove coil and flywheel, replace with ignition and new flywheel.
Result is same as Reids Cheeta DX.
Old 01-19-2005 | 07:40 AM
Wayne,
I did it to my very low time US41 using the CH system out of necessity. The magnet broke off the front of the case without a crash to help it. The results have been very satisfactory ... cheaper than a new case.
Bedford
Old 01-20-2005 | 01:33 PM
My Feedback: (58)
Hi Bedford, Did you see any improvement in top end and is it easy to hand start. How much does it weigh now. Is $ 169.00 what you paid for the ignition from C.H. Thanks for your reply. Wayne
Old 01-20-2005 | 08:49 PM
platero's Avatar
Try www.hpignitions.com.ar
Old 01-21-2005 | 08:57 AM
My Feedback: (119)
Personally, I like RC Ignitions much better than the CH conversion--It is cheaper than a CH (I have had more than 1 CH die on me and a few had developed RF niose--Ralph's has a lifetime warranty). It has a mechanical advance which a lot of people don't like, but I find it makes for a smoother transition.
Old 01-21-2005 | 10:19 AM
My Feedback: (61)
PM ralph at RCIGN1 His conversions are top-notch.. my guess is that his prices will be the same or lower and he does all the setup! You send him your engine and you get back the conversion.. FAST!
My friend has one of his converted G26's... runs like a raped ape!
DP
Old 01-21-2005 | 11:56 AM
My Feedback: (58)
Thanks guys, I will check out rctgnitions. Wayne
Old 01-21-2005 | 12:23 PM
My Feedback: (58)
Well I ment to say RC ignition. I tryed to look them up on the web but could not find them. Wayne
Old 01-21-2005 | 12:26 PM
My Feedback: (119)
Ralph is very actice here in the gas engines forum as RCING1---He should not be too hard to find.
Old 01-21-2005 | 12:31 PM
My Feedback: (119)
http://www.rcignitions.com/
Try this
Old 01-21-2005 | 01:46 PM
My Feedback: (58)
Thanks AJF-2, I found the website. I was not adding the ( s ) in ignitions. Thanks again Wayne
Old 01-22-2005 | 09:29 PM
Wayne,
The running of the engine is very good with the CH. I don't notice a difference in the top end, but do get a good, low reliable idle. Also, I find the guys at CH very helpful. I figure I lost close to 10 ozs. when I lost the flywheel and spring starter. As well as I remember (a few years back, it was), $169 is about the price I paid.
Bedford
