3W 140 Problems
Old 03-12-2005 | 11:36 PM
My Feedback: (25)
Default 3W 140 Problems
Hey guys I'm having problems with my 3W and I'm sure yall will have a suggestion on what the problem would be. I bought a barely used old style 140 TOC, broke it in and have 20 flights with it on a Carden Cap. Today I leaned it out a bit more and it ran great for it's first flight. Then I changed oil from husqyvarna to pennzoil air cooled and while doing vertical snaps 10 min into the next flight it died. 2 flights later I was in a harrier and it died and somehow got her down in the grass with no visible damage - still a hard landing. It never sounds weird it just dies in the air. I richened the needles out a bit and tried starting the engine, but now gas just bellows out of the carb like crazy and it won't stop. anyone know what's wrong?
Update:
I'm not very knowledgable with these engines so I just took the carb off from the carb block( I assume), took both needle vavles out and sprayed ALOT of carb cleaner in all these holes. I wiped anything dirty and put everything back together and the engine turned over but quickly came back to the old problem. Now when I put fuel in the tank it goes out the carb - I have to squeeze the tube to fill it up. When I can turn it over, it will not run under 1/3 throttle but will run to full power as if there was no problem. There seems to be gas not just comming out of the 90 degree carb nozzle but all around it as well. The fuel system has two filters in line and 2 before it goes into the tank - the carb screens looked clean....PLEASE HELP!
Old 03-13-2005 | 08:23 AM
Default RE: 3W 140 Problems
Take the carb to a small engine repair shop. Have them order a rebuild kit and fix it up. You could be assembling it wrong.
Old 03-13-2005 | 06:33 PM
My Feedback: (62)
Diablo is right. It is a carburetion thing.
It can be anything from the carb itself, to the phenolic block that it's mounted on. I have an old 140 myself, and it runs like a clock.
It always comes down to the big three, air, fuel, and fire.
I actually installed a DA carb block on mine. I didn't care for the characteristics of the phenolics. Mine runs consistent and strong.
If you stay with it you'll get it, and everything will be ok.
These engines take some time and patience to get right, but it's worth it.
Hopefully this thread won't go the "ford" "chevy" "DA" "3W" route.
Don't take this the wrong way, but it's not the engine, it's the user.
Old 03-13-2005 | 07:52 PM
Antique's Avatar
It's impossible for fuel to come out the carb when fueling if the carb is working right..the inlet needle takes at least 10 lbs to unseat, there's no fuel pump that puts out that much pressure...Take the steel cover off the carb...the inlet needle lever should be flush with the casting next to it...the lever has a little fork in the end..If the center metal part of the diaphragm is not hooked into this fork the needle will not close and fuel WILL go through the carb when the tank is filled...otherwise..NO WAY....
Old 03-13-2005 | 10:17 PM
My Feedback: (62)
You are right on RCIGN1. I noticed another thread on this topic by the same user in another forum, and it was indeed the fork...
