New ZDZ 80 RV-J
New ZDZ 80 RV-J
Just a quick note to tell everyone that the new ZDZ 80RV-J is now in stock
Pictured beside the standard ZDZ 80 Blue Line
Iain Nicol
www.iadmodeldesigns.co.uk
UK dealer for ZDZ
01236 423448
Iain Nicol
UK dealer for ZDZ
01236 423448
RE: New ZDZ 80 RV-J
Its not just biggar and heavier it also has a lot more power.
ZDZ have managed to improve on what was one of the best engines in its class
Iain Nicol
UK dealer for ZDZ
01236 423448
Iain Nicol
UK dealer for ZDZ
01236 423448
RE: New ZDZ 80 RV-J
If you have yet to run one -You will easily see power difference.-A setup you should like for the market there -is the big JMB can and the new ZM26x12 prop -which was -Iam told -shaped for that engine-
RE: New ZDZ 80 RV-J
ZDZ did not have to develop new 80s and 100s because they were so weak. ZDZ had to react to numerous engine faults in the german aerobatic F3A-X szene (similar to the US IMAC). There were cracks in the cylinder head bases and some Nikasil platings were rubbed of by the pistons. One 100NG started as a twin cylinder engine an landed as a 50NG single. The other cylinder was lying inside the cowl. The german ZDZ respresentative Amelung, know for his outstanding service, had a lot to do.
So ZDZ had to react quickly to preserve its good reputation which was build up during the las few years. Hopefully the new engine will work. And I hope MY 100NG will not collapse.
Joe
Joe
RE: New ZDZ 80 RV-J
Every mfgr has had some failures - 3W also had case failures-I have seen these personally -these problems were isolated and were warranteed immediately
The new engine design, is a performance upgrade .
RE: New ZDZ 80 RV-J
ORIGINAL: FreedomFlier
How much does the new engine weight?
2000gr, bare engine, according to RCS
