Several Quadra Q75 Questions
Hello,
I purhased a plane last week with an old Quadra 75 engine. I have a few questions I am hoping someone can help me with:
1. What size prop would be a good start for a 1/4 scale ME 109G (I would like at least a 10 pitch prop)?
2. Can I use an oil mix of 50:1 with Mobile MX2T? I am using this on my other gasser and it would be convenient to use the same can for both.
3. I can't tell which mixture adjustment is the "H" and "L". The engine is in a tight cowl build and only the bottom portion is removable. Of the two adjustment screws, one is closer to teh mouth of the carb than the other. If this isn't enough information, perhaps I can post a photo.
-Ed
-Ed
