Who has Menz 27x10 in stock?
My Feedback: (8)
MO
RE: Who has Menz 27x10 in stock?
I've been looking for Menz's props for a month. Nobody has any in stock. I wound up just buying a NX prop, it's a better looking prop anyway.
My Feedback: (16)
Cap...Have you tried the Nx prop? Is it the pro series? What engine did you put it on. Mine is a DA 100. Mainly gonna try to use for 3D.
Smokey
Smokey
My Feedback: (69)
AR
I ran the NX pro 28x10 on my 106, great prop, only drawback is its loud, but I like em loud. As good or better than a menz IMO. The NX pro 27x10 would be a better choice for the DA.
My Feedback: (69)
AR
It worked very well for 3D, spins up fast, and lots of control for the tail. I would recommend the 27x10 on the DA though, as they are a little more load than a menz. If your plane was only 22-24lbs you could probably get away with the 28", but any more than that I would go with the 27". Plus, the props look very cool, and are light. I have tried almost every wood prop except MSC, and liked the NX Pro the most.
My Feedback: (69)
AR
Most definitely the 27x10 then, if it weighs 29lbs, I would probably still go with the 27x10 even if it was a 106 pulling it, really hard to throw around a 29lb plane like a shock flyer with any 100cc engine.
