Reversing a Zenoah
Reversing a Zenoah
Does anyone have any knowledge and/or experience with reversing the rotation on a Zenoah 23 or 26cc motor. I am referring to the motor itself not a gearbox. Thanks.
DC
RE: Reversing a Zenoah
Easy to do with a CD ignition, just put the sensor in a position to fire on the other side of TDC..I did it with a 23 magneto engine, take the key out of the crankshaft and re position the mag rotor by trial and error and turn the source coil the other way in the mount....Won't work with an old points ignition G23....OR switch it to glow and start it up backwards..
I would like to counter-rotate one engine in my twin engine 73" Cigarette that I manufacture. I had counter-rotating Kanellos outdrives originally that took care of the problem, but they are not being made any more as far as I know. MHZ drives are an option, but they do not keep a counter-rotating drive in stock.
My Feedback: (29)
TX
Hi,
It sounds like you are talking about a boat application. Is this the case. You may be able to flip the flywheel to get reverse rotation, depending on how it is keyed.
Dave
Dave
DC
Don't know about torque, they turn in the 14 to 16,000 rpm and above range...The speeds are now over 100 mph...Peak torque is at 9000, hp peak is at 12,000 for the boat/plane engine, 13,000 for the heli engine......
My Feedback: (61)
Ren3 ... PM with your web adress... I would like to see one of your boats! I own a 38' Top Gun, 520 power Arneson Drives... maybe one of your boats could keep up with mine!
Check out Rod's Skater too..... http://www.arneson-industries.com/sorcerer.htm hottest boat I have ever seen or flown in !
DP
DP
