g62 mounting Template
Old 10-03-2005 | 07:46 AM
Default g62 mounting Template
I just recently purchase a g62 engine w/o the manual. and the manaul online does not have it. Do anyone know where I can download a copy of this template. And what is the recommended gap on the plug of a g62.
Old 10-03-2005 | 08:19 AM
My Feedback: (118)
Default RE: g62 mounting Template
Here is a link.
http://www.horizonhobby.com/Shop/ByC...ProdID=ZENE62A
There is also a manual in PDF format off the same page.
Safe Flying!
Old 10-03-2005 | 08:25 AM
I have a copy of this manual from horizon, but there manual does not have the mounting template in it. I think template only comes with the manual when you purchase the engine.
Old 10-03-2005 | 09:37 AM
My Feedback: (118)
The drawing on the bottom of the page on the Horizon site is as close to a template as you will get. The dimesions are in inches, but the engine is metric. Even on the Zenoah site, www.zenoah.net there is no template. The manual on their site is exactly what you get when new. The G-62 is easy as the holes are spaced evenly. Just draw your own template off the dimensions.
Safe Flying!
Old 10-03-2005 | 10:12 AM
Antique's Avatar
The plate is a rectangle..3.940 x 3.400
Holes across the top and bottom are 3.400 apart
The holes up and down are 2.630 apart
The holes in the engine are 1.496 inches apart
Hole diameter in the plate is .214
