DA 50 spinner bolt broken/stuck
FL
Was at the feild yesterday flying my WH Edge 540 w?DA 50 and my spinner bolt snapped of in flight, this was the 26th flight and I check it and my prop bolts about every 5-7 flights now. The problem I have is that the rest of the broken bolt is stuck in the shaft of the engine and won't budge, won't even come out with a Easy-Out. Has anyone else had this happen to them, if so what did you do, would DA replace the shaft if I sent it in, or is there another way to secure the spinner without using a 3 1/2 inch long bolt?
My Feedback: (41)
RE: DA 50 spinner bolt broken/stuck
What brand spinner is this? I know that Dave Brown once told me (on the phone) that he doesn't like those spinner bolts getting too long for the exact thing that happened to you. There should be an adapter if it's that long. Must have been an ultimate spinner. Also how tight did you tighten the spinner bolt?
The "shaft" that the spinner bolt threads into is just an adapter that threads onto the end of the crank. Very easy to replace. I couldn't imagine a new one costing very much if you can't get the broken screw out. I wouldn't expect DA to replace it for nothing. I see no reason to check the prop and spinner bolts every 5 flights. I tighten the prop bolts "very" tight when I install the prop and then use locktite on the spinner bolt. No need to crank it down hard. Never had either come loose. Possibly a combination of a cheap bolt and over tightening is what caused it to snap in the first place. Just a theory.
Mike
Mike
FL
Huggins, the bolt I was using on the spinner was a TRU-TURN 3 1/2 inch long bolt. How hard is it to change that shaft....??
My Feedback: (10)
FWIW, True Turn says in the instructions to tighten their spinner bolts with two finger holding the small end of the allen wrench. That's not much torque. I've been doing it this way on my TT spinners for years and have never had a bolt break or spinner come loose, no locktite either. They just don't need to be that tight.
ORIGINAL: shogunmst
Nogyro - I know a lot of people don't use locktite on the their spinner bolts, but I lost one off of a Saito 150 during flight one time over a corn field. It damaged the prop and I wrote both off as a loss. Funny thing is, about 2 months later a friend found it! Now I have and extra 3"er. Anyway, I started using Locktite after that and continue to do so.
My Feedback: (41)
That's the same method I use and never a problem. I gotta say though, this new 3.5 inch TT Ultimate spinner that Chief Aircraft just shipped me has one of those long bolts. It's the spinner that is factory cut for a DA50 and a Menz 24x8 (also lightened back plate). I got a little worried after reading this thread because the bolt on mine very long. I haven't run it on my DA50 yet.
ORIGINAL: Nogyro
My Feedback: (10)
ORIGINAL: JoeAirPort
My Feedback: (41)
The spinner looks cool a hell, you should see it. I finally got the cowling mounted on my BME Edge II and saw the spinner mounted. Very cool looking. Like I said I hope that bolt holds up. I wonder if the guy that started this thread had that spinner? The bolt on mine is 3.5 inches long too.
ORIGINAL: Nogyro
I must say that I've never ran the Ultimate spinner before. All mine have been the P51 style with the lightened back plate. That spinner bolt must get pretty long with the Ult. Spinner.[8D] I'm running the 3 1/2" on my DA50's, and I ran a 4" on my G-62/Giant Stinger.
Your situation with the spinner bolt isn't uncommon. It's been happening with the 35 and 40% crew off and on for a long time. Using a hardened bolt will help, but not prevent the situation. If you tighten the bolt enough to deform the spinner back plate the chances of the bolt breaking increase considerably. Just snugged up is actually tight enough. Four strokers are another can of worms altogether. When they back fire, nothing stays together[:@]
Use a tiny dab of anti-sieze on the end of the bolt the first time you install it. It will help in the extraction if and when it breaks.
My Feedback: (10)
ORIGINAL: Silversurfer
That was the point. Using Lock-Tite on a long, unsupported bolt causes a lot of twisting force additional to that normally applied (without the Lock-Tite) to be applied to the center section of the bolt during the removal process. How many times can it be twisted before it weakens enough to snap under rotational stresses? I'm not going to guess at that number, but it has to be a finite quantity.
CA
ORIGINAL: Nogyro
LOL Silver, you suggest anti-sieze on the spinner bolt, and some guys are using locktite.........How's that for contrasting views.
There are a lot of people that don't like the one stud/nut set-up, but I will guarantee you it will never shear.
My Feedback: (10)
ORIGINAL: RTK
Does not matter if lock-tite is used, if the prop compresses the bolts will shear. The bolts are not there to keep the prop from rotating due to there shear strength, but to apply a force so friction will stop the slippage.
Uh......................we're talking about spinner bolts, not prop bolts.
CA
You mean to tell me they aren't one in the same? Bolts is bolts right. Dang, no wonder I'm having such problems lately. Well besides my latest disease.
I'll call you later Silver
