View Poll Results: A poll
Voters: 51. You may not vote on this poll
Your Favorite G62 Options
PA
Just got my first gasser, a stock bare bones G-62. What are your favorite options for this engine? Thanks, this will help me decide how to proceed! (You may choose more than one answer.)
My Feedback: (91)
RE: Your Favorite G62 Options
JD Hammer, You'll really like the G-62. It's user very friendly and provides plenty of power for a lot of applications. While it's hard to improve the "STOCK," Zenoah G62, these are two "MODS" I feel add to the the overall and performance and reliabilityof the G-62.
1: After market muffler for quiter ride and improvement in Performance.
2: Electronic ignition for smoother Idle and better transition. I Suggest Ralph Cunningham, ( RCignition).
I always put electronic ignition on the Zenoah engines, and I always install an aftermarket muffler. I usually slap a wrap-around pitts on them because it makes the cowl and installation look cleaner.
You don't always gain power with a pitts, but they sure look good. It CAN'T be worse than the restrictive stock muffler.
Ralphs ignitions are very good. I have used them numerous times and not had a single problem. Ralph stands behind his product too. If you have problems, he's just an email or a phone call away.
While you may not necessarily NEED a synchrospark (variable timing) unit--it sure does make the idle smoooooth. Stock magneto equipped G62 engines tend to shake a bit when idleing. The electronic ignition unit really smooths it out.
One suggestion that wasn't in the poll--use 32:1 or 40:1 oil in this engine. You don't need to waste money on expensive synthetics that require a 100:1 mix. Any 2-stroke chainsaw oil from the local big box will work just fine if you mix it according to the directions on the bottle. I prefer Husqvarna oil mixed at 40:1. Costs about $1.05 for a 3.2oz bottle--perfect size for 40:1 in a gallon of gas.
CA
ORIGINAL: Bob Laine
1: After market muffler improvement in Performance.
TX
Go to an electronic ignition way safer if your hand starting too. Also get some of the stand off mounts from chiefs or some where no need to use the cup types, hey are too heavy. You can actualy get the weight down to equal some of the higher priced engines and the G62 will make good power if equiped.
PA
Thanks guys, I'll be sending the engine to RcIgnitions next week and a Bisson muffler is on the way. Looks like not many go for the no-vibe mounts. One post said that it causes more problems than it cures so I'll leave them out. This engine will be powering a TF giant Corsair so the more weight up front, the better!
