2 Quick Questions About Gas Engine
Old 11-09-2002 | 11:30 PM
Default 2 Quick Questions About Gas Engine
HI I AM NEW TO GAS ENGINES WAS WONDERING HOW THE GAP ON THE COIL IS SET ? IS THERE A GUAGE OF SOME SORT?AND WILL PAINTING THE FINS PREVENT PROPER COOLING? THANK YOU
Old 11-10-2002 | 01:52 AM
Coil gap is .010 .A calling card works fine. Fins can be painted. Use automotive high temp. paint . Just light coats.
Old 11-10-2002 | 01:55 AM
Coil clearance isnt critical......most advice says use a dollar bill folded once,a business card,or a .010 feeler gauge.
I suppose I wouldnt argue with any purist who says paint on the fins would affect their ability to radiate heat to some extent.I have painted a couple of my engines with hi temp engine block paint (Cummins Diesel Green!) with no noticable affect although I didnt use a temp probe before and after.....
Old 11-10-2002 | 02:34 AM
I set coil gaps at .010", using feeler gauges. I paint fins and mufflers with Rustoleum - high temp. flat black spray paint made especially for gas grills. Works great.
