Ebay G62's, new, deal or not?
RE: Ebay G62's, new, deal or not?
I called C H ingintion and he thought he make a hub for 50 dollars. Anybody find one cheaper? I guess the g45 has the same hub. Still horizon list it the same for 60 dollars with no thrust washer.
Ron
Ron
Wacker Engines will sell you one for around 20.00 plus shipping. I have purchased several prop hubs from him. I am pretty sure that they are the 5/16 tread hub. You can give him the length that you want and he will make it to order. Pete is a real nice guy and very helpful. His includes the hub, bolt and washer. Very professionaly done.
DC
G62 cranks are 10mm..The crank and prop bolt are not the same thread, the bolt is 10mm but coarser..A screw on hub would work better if you counterbore it for the top part of the mag rotor, more contact area...I'm making my new G62 lite hubs to screw on, but my hub is different...The material should be 2024, 6061 strips easier....
If you use a screw on hub, use green Loctite 609 or 638 and get it TIGHT....
