Isolator for electronic ignition?
Old 01-12-2006 | 06:19 PM
kevinbell's Avatar
Default Isolator for electronic ignition?
Can anyone tell me if it's really necessary to have an isolator with electronic ignition?
I'm building a 3rd scale Extra 91" span but wont be ready for a while and want to by a cheap smaller plane using a petrol engine.
A Blackhorse Cap 232 80" span with a 45cc MVVS engine. It has electronic ignition, does this mean I need a isolator with that one as well? I'm trying to keep the plane light, so if I don't need it then I wont bother but if I get interference from the high tension lead then I'll need an isolator..... Is this true???
Kevin
Old 01-12-2006 | 06:47 PM
Antique's Avatar
Default RE: Isolator for electronic ignition?
The ignition is all shielded except for the power wire...If you keep the ignition battery and switch away from the receiver and battery there should be no problem...No RF can get by the shielded spark plug wire and cap...
Old 01-12-2006 | 07:08 PM
Whats an isolator?
Old 01-13-2006 | 06:16 AM
My Feedback: (18)
Yes, just what is an isolator.
Old 01-13-2006 | 03:57 PM
kevinbell's Avatar
Sorry it's an Opto Isolator.
"The Opto Isolator Unit is designed to electrically disconnect and isolate all servos and their associated wiring from the receiver, thereby removing all radio frequency interference entering the receiver via the servo connections. The use of this unit has several other benefits including improved receiver operating range and the possibility of running the servos and receiver on different supply voltages. The unit is supplied with eight short fly-leads fitted with universal plugs for connection to the receiver and eight standard pin connectors for connection to the servos".
This is from SM Srevices
http://smservicesuk.co.uk/acatalog/L...del_Units.html
Old 01-13-2006 | 06:57 PM
No it is not necessary
Old 01-13-2006 | 08:59 PM
hey ive been running gasser fir years and have never put in a isolator just keep the module and switch for the battery away from the rec on my challenger the switch is up by the cowl and the module is under the cowl
Old 01-13-2006 | 10:09 PM
Naw, ya don't need one of those.
Old 01-14-2006 | 07:30 AM
kevinbell's Avatar
Thanks for all the info! It will save me money and weight. Battery, isolator, huge amount of wiring is about 200g or .44lbs.
Cool.
So just keep the switches and battery for the receiver as far away as possible from the switch and battery for the ignition? Any added insulation?
Kev
Old 01-14-2006 | 09:16 PM
cyclops2's Avatar
If you put every new" Must have, or it will crash gadget in your plane."it will not be able to fly.
My safety electrical gadgets are, 2 wraps of black electricans vinyl tape, to keep all plug and sockets together. Period.
Old 01-16-2006 | 06:34 PM
Kevin,
Are you using an ignition kill switch from SM?
Old 01-16-2006 | 06:57 PM
kevinbell's Avatar
Hi Peter,
I'm still building it and don't have the engine yet. I like to do my homework before I spend money. I thought you close the throttle like a glow engine?? Kill switch??
Kevin
