Lightest Engine
Old 04-14-2006 | 09:20 PM
WRK
Default RE: Lightest Engine
For comparison sake what is the thrust with a G62 lite after break-in and with what prop?
Old 04-14-2006 | 11:19 PM
Antique's Avatar
I have seen about 28 with a 22-10 Zinger at 7000, maybe one of my customers has measured it...
Old 04-14-2006 | 11:35 PM
RTK's Avatar
RTK
A Zinger[X(] There must be a better prop out there that someone has tested. I really need to put an rx in my Sukhoi and run the Mejz 28x10 that I have on my G62L.
Old 04-16-2006 | 02:24 AM
Antique's Avatar
28-10 ? Good luck
Old 04-16-2006 | 07:59 AM
My Feedback: (117)
I'm sure interested in this motor. What are the rear mounting/bolt space/ demensions? Thanks Brian Smith
ORIGINAL: sbaugz
Check out the BCMA 26 cc engine seen [link=http://www.bcmaengines.clearwire.net/BCMASPE.htm]here[/link] . Weight is 38 ounces. I just got mine. Haven't started her up yet, but its a great little engine.
Otherwise, check out the RCS 140 or 180 or the Roto 25 from RC Showcase. They are pretty light too, but also cost about $300 more when all is said and done.
Old 04-16-2006 | 08:12 AM
  #31
RTK's Avatar
RTK
Oops typo, 22x10
ORIGINAL: RCIGN1
28-10 ? Good luck
Old 04-16-2006 | 10:11 AM
  #32
Antique's Avatar
You OLD guys are all the same
Old 04-16-2006 | 10:27 AM
  #33
RTK's Avatar
RTK
Said but true......... I do have a 28x10 mezj though
Old 04-26-2006 | 10:17 PM
  #34
Scott Ellingson's Avatar
My Feedback: (146)
Email Adam, [email protected] , He will get you an EI from them. I bought 4 of his little SPE 26 engines, but don't want the EI thay come with. I like CH and will stick with it. So he will have 4 units looking for a home.
What is a good 38cc class engine to do. Poulans in that size are toooo heavy, Homelites aren't much better. McCulloch 38's are needle bearing. What is left without paying an arm and a leg?
