Brillelli Boyz
#427
KS
RE: Brillelli Boyz
Zippi, I think he's talking about the magnet that sits in the flywheel ring (behind the prop hub) and rotates under the EI pickup. I had buddy that had his come out and Scott took care of it.
#429
My Feedback: (198)
RE: Brillelli Boyz
Well, since Sturtz is also a flying buddy, and we fly together, and he has Brillelli's and has been a cheerleader since I got s/n 2 of the Brilleilli 60, I feel I owe it to everyone to give the "update".
1. This motor is an absolute HOSS. Tonight (overcoming my own objections to the contrary), another flying buddy measured my Brillelli IMMEDIATELY post landing, and following a 20 second full-power run at 90* to the wind. Plenty hot. NX 23 x 8 turned solid 6600, maybe a little more, and temps at shutdown were between 170 and 190, depending on where the laser temp gun was pointed.
2. After choke burp, this motor starts on flip #7. Not really "flip", more of a "slap" (but not hard) through TDC. And then it never misses.
3. This setup, with a full 24 oz smoke, smoke battery, and TME system weighs nearly 19.5 lbs at full wet takeoff weight..... and it will pull dead straight vertical and fly out of sight, never slowing, always rolling (if I want)....and never misses.
OTHER people who have 50cc motors and wish they had a "little more" NEED to contact Scott and get on the list.... this motor is DEFINITELY a keeper, and I am VERY glad to have it.
(Sturtz can attest to these statements - he's been there every time I've had this one out!!!)
#431
My Feedback: (12)
RE: Brillelli Boyz
Zippi, water.boy has it right. I didn't explain it very well. If that little bugger comes out you have no more ignition, like shutting off the switch. Good luck, you have been having more then your share of bad luck.
Later
Skinny Bob
Later
Skinny Bob
#432
NM
RE: Brillelli Boyz
Fellas,
Without reading this entire thread, can anyone tell me which Brillelli engine would be most suitable for a Hangar 9 P-51 1.5? Does anyone out there have one (or know someone that does have one) in this Mustang? It seems like it will be a tight fit for a gas engine in that engine compartment. Any ideas out there?
Gary
Gary
#436
My Feedback: (146)
MN
RE: Brillelli Boyz
That was me taking video. I need practice at that. It was marks CE. Tony Bjerke was the pilot. He is awsome. He never flew a CE or Pitts before so he did very well with a plane that is not made for 3D.
#437
My Feedback: (20)
OK
RE: Brillelli Boyz
Here's AeroBob's home sick angel rolling skyward with gobs of UPWARD to spare. Pic could have been better but I forgot to switch the zoom focus.
And that was the maiden flight. Every flight afterwards the engine just keeps getting stronger and sounding fuller.
Bob would tweek the high end a click and go back up putting the plane and engine to all the tests.
The plane will now hide itself in a smoke cloud when he switches on the show juice during torque rolls and tumbles.
The sound coming from the 60cc in that big Yak cowl is simply awesome !!
#440
NM
RE: Brillelli Boyz
sinergy,
Most people's have been coming in around 14-15 lbs with engines such as Saito 2.00, Saito 1.80, OS 1.60, and similar. The wingspan is 77". It can be seen [link=http://www.horizonhobby.com/Articles/Article.aspx?ArticleID=1334]HERE[/link]. I think you're right, the 26 probably isn't enough.
Gary
Gary
#442
My Feedback: (10)
RE: Brillelli Boyz
Looks like Skinny Bob & water.boy hit it right on the money. The little magnet that mates up to the Hall Sensor did in deed come out and was still inside the case. Once again customer service kicks in and Scott is on top of it with a fix. I gotta tell ya, if you don't buy Brillelli you just don't wont to get your moneys worth.
#443
MI
RE: Brillelli Boyz
Alright fellas, looking for guesses/opinions on how my set up is going to perform - I'm going to finally madien my 27% CA Extra (84" wing) this weekend. Can't freaking wait.
I have the 46GT with EI turning a 22 x 8 NX. The plane was expected to come in between 15 - 16#, but I have the tendancy to overbuild everything I touch so I wound up at about 16.5# (don't even have a spinner for it yet and at that weight, it may not get one ). I'm not looking for 3D but rather will use the plane for learning IMAC type aerobatics. Hopefully it'll pull well in uplines.
Any guesses as to the performance and power I might expect? This is my first giant scale/gas so I'm relatively clueless.
#444
My Feedback: (40)
RE: Brillelli Boyz
Well I dont have any expereience with that plane it looks like it has more wing area then a 25% GP Patty. Weight wise I think the motor will do fine for what you are trying to fly. Verticle should be suitable as well.
I think with the bigger wing at that weight you will have a floater... however at a cf tube light batteries and maybe a lighter gear and it will be night and day difference.
If this is your first big gasser I would double check your rates... you have to remember with a bigger plane you cant be banging around the el. with too much throw or you will stall it. Read what the manual says and don't madian it thinking I can do this no problems on high rates.
Other than that I think you will come home with a smile on your face
#445
MI
RE: Brillelli Boyz
Well, no maiden - I couldn't get a range check. I posted this in Giant Scale, but I thought I'd throw it out here since it is a Brillelli motor. Any advice would be appreciated.
I followed all the precautionary measures I've read about to help eliminate EFI, but apparently I lost that battle. I can get a great range check with the engine not running, when the engine is running I can't get more than 15 feet away before everything starts jumping - this happens only when I walk away from the plane on either side or the rear. When I walk out from the front of the plane and stay directly in front of it, I can get 75 - 100' away before chatter begins. The antenna is running out the top of the plane to the rudder. (It didn't like it inside the plane at all - couldn't get more then a couple feet away.) I tried two of the same Rx's which I flew both in another plane fine. So I'm convinced it's not the Rx or antenna.
Here's what's in the plane:
Plane: 27% CA Extra
Engine: Brillelli 46GTEI (Ignition module mounted in front of the firewall)
Switches: Cermark HD, one for EI, one for Rx spaced 15" apart
Batteries: NoBS NiMh - 1400 on ign mounted just behind firewall, 3200 on Rx mounted just behind wing tube socket (batteries are 11" apart, any Rx wiring is at least 14" from any EI wiring)
Servos: Hitec 5645s all around
SmartFly Eqaualizer II splitting elevator servos (24" HD twisted extensions feeding both elevator servos in rear)
Rx: Futaba FPR127DF
6" HD twisted servo extensions feeding ailerons
No choke servo
Throttle servo is located back by the Rx, linkage is Sullivan graphite Nyrod
No metal to metal connections on any servo or linkage (except choke)
Choke control: short piece of 440 metal rod coming through the side of the cowl, connection to choke is all metal (could this be acting as a EFI antenna?)
Kevlar on the pull pull
I'm rather frustrated though - good weather is winding down and I can't fly a plane I've put more than a year's work into - its' DONE but I can't fly it. [:@]
Sorry for the long post. Thanks for any advice.
Bob
Plane: 27% CA Extra
Rx: Futaba FPR127DF
No choke servo
Bob
#448
My Feedback: (10)
RE: Brillelli Boyz
flymeaway,
These guys are on top of it. Believe me when they say "!No Metal To Metal Contact". I had to learn the hard way. The Bosch cap is great. It eliminates the ground strap and has a nice clamp provided. Thats what solved my glitches and I had enough of them. When I ordered my 40cc I had scott put the Bosch cap on it as well.
#449
My Feedback: (146)
MN
RE: Brillelli Boyz
Gary,
PM jstanton. Someone at his field has that plane with our 46 in it. He got it to fit pretty well. It has the power you will want. A 40 would be a little low on power I think. The 46 would bring it to life.
#450
My Feedback: (14)
RE: Brillelli Boyz
Gary ,
Here is a video of Topflites Giant P-51 with a Brillelli 46 engine. This plane has the 46 with the magneto on it so it is a little heavier than one with EI. The 46GT flies this plane very nicely. This was the maiden flight so the video is not very long, but you can see how well the Brillelli 46 does on this plane. Good Luck.
http://media.putfile.com/Brillelli-46cc---P-51-Mustang-
