how long will it run
My Feedback: (25)
NE
Just wanted to know about how long my 26cc gas engine would run on 14 ounces of fuel? Im tyring to decide if I should put a little bigger tank on or leave the 14 ouncer.The other one I was thinking about is just a little bigger maybe 2 ounces top no more, would this even be worth it or should I just leave it?
My Feedback: (13)
OH
Depending on the weight of your plane, how he carb is tuned, and how you fly, it should run long enough for your neck to get stiff. Just going on other gas planes that I have seen, it should run for 20 minutes, maybe more. I wouldnt change a thing.
My Feedback: (24)
If my .91 four stroke can run 20 minutes on a 14 oz tank at full throttle, then a 26cc gas engine should run for at least 30 minutes. Gas engines do not drink as much fuel as glow engines. I'm flying a 39cc gas engine on a 20 oz tank, and I should have used a 16 oz tank or even 14 oz tank.
FL
I have a BME 44 with a 14 oz tank in a HP 80" Cap232. I can fly 13 minutes of IMAC type stuff and still have 1/4 of a tank left when I land. You could probably do 16-17 minutes of full throttle with a pretty good reserve. Me, I get tired after about 12 minutes!
ORIGINAL: rc pilot
Best wishes,
Dave Olson
I have a BCMA 26cc on an Ultra Stick Lite with a 14oz tank. You could get away with a 10oz easily! My flights average 10-12 minutes and I burn about 4oz of fuel in that time. Even flying it very hard and stretching it to 15 minutes, I still have 1/2 tank of fuel when I land.
CO
Hi Guns,
I'm thinking of getting the BCMA Sport 26-IV for an Ultrastick Lite. The weight of this engine with muffler and exhaust is 36 ounces. Will I have to mount the servos in the tail to balance?
