VASS prop for the DA50????
I'm looking for a good prop for my DA50. the engine is broken in and until now i've been using menz 22x8 but, the engine is ready for a good 23" prop.
would the VASS prop's be a good choice? could anyone recommend the proper VASS prop? (A,B,C)
right now i'm flying the WH 28% edge and building a CA26% extra 330. my style of flying is mostly 3D.
thanks
thanks
the problem is that both the planes are very different. the WH weighs 17lbs and the CA extra will probably be under 15lbs so, i need a prop that works with both of these air frames. like a 23x8 would.
My Feedback: (40)
NH
Well, any prop will work with them both, but which would be the best suited? You won't know without experimentation. I had my 23a on a QQ Yak first, and I didn't like it, it limited the speed too much from all the drag. On my Ultimate, it's perfect. There are 3 pitches, A,B, & C , buy one of each, props are a tuning item.
