Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 Hangar 9 Extra 260 Engine Selection >
Old 11-15-2006 | 01:41 PM
Default Hangar 9 Extra 260 Engine Selection
I can't decide which engine to put on my Hangar 9 Extra 260.
Tell me what you guys are running or what you'd recommend on this aircraft to do aerobatics and some mild 3D
Thanks.....Dave
Old 11-15-2006 | 03:26 PM
Jake Ruddy's Avatar
My Feedback: (40)
Default RE: Hangar 9 Extra 260 Engine Selection
You want between a 40 and a 46.
I have seen one fly on a 26 and umm well it flies! Loops are barely doable. Do not waste a 50cc on this plane.. it's light and will fly better with a lighter smaller engine.
Hope this helps.
Old 11-16-2006 | 09:57 AM
My Feedback: (172)
I went through the same process and decided to go with the Brillelli 46 w/ Elec Ig for a Hang 9 , 260 extra. Scott @brillelli says I'll have the engine by next week so will hopefully post some more info on performance by thanksgivings. Stay tuned.
Old 11-16-2006 | 02:22 PM
Jake Ruddy's Avatar
My Feedback: (40)
Well you made a good choice and will have tons of power for sure.
THe weight difference is only a few oz. and a lot more power
Old 11-17-2006 | 11:07 AM
BaldEagel's Avatar
Dave
Have a look at the Evolution or MVVS 45 Magnezium, I have one of the new MVVS one's with the automatic choke, it outperforms all of the other Petrol engines at my club up too and including the 50cc one's and its lighter. This is while I am still running it in on a Oil mix of 30:1.
Mike
Old 11-18-2006 | 12:16 PM
Thanks Guys
Dave
Old 11-19-2006 | 01:42 AM
HangerBum's Avatar
I put a ZDZ 40RV on mine. Plenty of power, love the setup. 14 lbs 2 oz
Old 05-31-2007 | 10:00 PM
My Feedback: (7)
So is a g26 on electronic ignition out of the question?
Old 05-31-2007 | 10:17 PM
DL-50... would be way overpowered like my carl goldberg 330
Old 06-01-2007 | 08:15 PM
rc-plane's Avatar
I was trying to find a good engine match for this plane also. At first I wanted the DA 50 but now I dont know. If I dont get the DA then I was looking at the brillile (SP?) or the evolution. What do you think will be better?
Old 06-01-2007 | 11:05 PM
Jake Ruddy's Avatar
My Feedback: (40)
ORIGINAL: I_Fly_Coolers
Well it flies... I flew one for a club member... really lacks vertical... but if you just want a fun day at the field it's fine.
Old 06-01-2007 | 11:08 PM
Jake Ruddy's Avatar
My Feedback: (40)
ORIGINAL: rc-plane
Personally a DA 50 is overkill on this plane.
I would be looking at the Brillelli 46 as that would be more than enough power. Evolution is good too... but they are costly and require a pipe to come alive. If you got one without doing a pipe thats just a waste of money IMHO.
Brillelli also has a 50 that is as strong as a DA but $495 with muffler.. so almost 200 cheaper. However I would probably stick with teh 46 at $375 it will have more than enough power and save you money.
Old 06-02-2007 | 02:20 AM
I fly this model with a ZDZ40 rear exhaust with a cannister. Flies great, is excellent for 3D and IMAC. It not ballistic on vertical pulling out from a hover but does have plenty of power.
Old 06-02-2007 | 07:03 PM
I just put this plane together as my 1st giant scale. I am running a DA-50 and love it! Tons of reliable power, and if you get into trouble practicing 3d it will yank you right out.. I was in your same shoes not too long ago about the engine selection for this plane. DA-50 is too much for this plane, don't waste your money on a 50cc ect... I figured eventually I'm going to step up to a larger 30% airframe and need a 50cc and thats why I went with the DA. The H9 260 flies great with this setup for me, and I could not believe how slow the plane comes in for landing. With a little breeze you could almost keep up with it at a fast walking pace. Anyway thats what I went with and am very pleased.
Dave
Old 06-02-2007 | 09:01 PM
My Feedback: (36)
I have a Saito 220 and a DA 50 I'm going to try, if it flies good with the Saito, I will stick with it to keep the weight down and put the DA on a 30%
Tom
Old 11-18-2007 | 09:17 PM
thinking of putting a saito 300 twin in mine what do you all think?
Old 12-26-2007 | 01:42 AM
cobra525's Avatar
Is anyone flying this on a SAITO 180?
Old 01-05-2008 | 04:10 PM
YA MINE HAD THE SATIO 180 ON IT AND IT PULLED IT LIKE MAD TOOK IT OFF AND WENT TO A DA 50 WITH A VESS 23B PROP AND COULDENT BEE HAPPER
ID:	842991   Click image for larger version
Old 01-18-2008 | 11:29 PM
i put a da-50 on mine, love it.
Old 01-22-2008 | 07:59 PM
I just orderd my 260 and have a satio 220 for it, please someone tell me this is a good pick.
I want to hover and need power to pull out of it.
Old 01-24-2008 | 12:24 AM
yes, I'm flying it with a Saito 1.80 and it has plenty of power. I'm spinning an APC 17X6 prop, however I'm having a little trouble slowing it down on final. Any suggestions?
Old 01-31-2008 | 12:20 PM
i have a new yamada YS 170 dz and i am going to glue it on the nose of this nice bird i am building. does anyone any idea about it ?
thank you ciao francesco
Old 02-10-2008 | 01:46 PM
i have a crrc 45cc in mine it has bags of power and is not to heavy, absolutely love flying it
Old 03-03-2010 | 11:34 PM
ORIGINAL: hunternfla
I am actually getting into giant scale airplanes. This extra would be my first one. DA 50 plus muffler=. Just way to expensive. So, i'm thinking of buying a DLE 55 with a DA 50 pitts muffler.
The only question is how do you mount the engine so that the thrust lines match up and it matches up with the cowling. Where would i find the thrust lines on the engine? I know basically you find the thrust line on the engine and then match it up to the thrust lines on the firewall, but on a Gasoline engine, i have no idea where to find them.
Also, how is the reliability of the DLE engines. I heard that they were DA copies. Would it be enough power to hover with plenty of reserve with the weight of a smoke system?
3DKunalud
<br type="_moz" />
Old 03-04-2010 | 02:45 AM
My Feedback: (14)
A fellow has a video posted on You Tube of this model being powered by a Saito FG-36. An excellent match.
Ed Cregger
