Engine Mount for EV0 35
WA
Season Greetings :-) I have a Evolution EVO 35 that uses a standard beam mount. Problem is that I cannot find a good alum beam mount that is rated for this large of engine. I would prefer something with some dampening action but will consider anything at this point. Dubros makes one that is rated for a 180 4 stroke and it appears to be big enough just worried about the rating. Thanks for any help.
Best regards,
Randy
Best regards,
Randy
WA
Yes I seen that but I was after a beam mount to make adjusting the length easier than the radial mount. If I cannot find one I may have to use it though.
Thanks..
Randy
Thanks..
Randy
See Item # 3398R at http://www.mvvs.nl/MVVS/main_bestanden/pricelist.html
It is a radial back mount that fits directly to the rear cover. Iso mounts are not included, but you can add dubro mounts without any problem.
