3w 48b2 twin engine
MN
Hey all, can somebody give me some info on 3w's twin 48cc? does 3w still sell them? have they been discontinued? please, any info will be good! also, could i run a xoar 18-6 on there, or is it too small?
My Feedback: (30)
Hi,
the 3w-48 has been replaced with the 3w-56. I have 2 of the 48s and they are a smooth running engine. While they are rated at 0.2 hp more than the 3w-50 single, they turn a 22 x 8 about 100-200 rpms less than the 3w-50 single. The 48 is rated at 5 hp where the 50 single is rated at 4.8 hp. The 56 twin should be more powerful.
Elson
Elson
MN
thanks a ton for the info. I plan to put it in a DP extra 330L, and was debating between that and a DA 50. however, i think i like the idea of a dual cylinder. what do you think of single vs. dual cylinder?
My Feedback: (36)
ID
I have a 48, neat little motor. The advantage of a twin is they are smoother running and sound better, other than that, it's hard to justify the extra weight and expense. Got mine used cheap, and I run a 22X10 on it.
Tom
Tom
Only small downside is the little extra weight.
