poulan 52cc ??
Old 02-23-2003 | 03:31 AM
My Feedback: (29)
Default poulan 52cc ??
Was walking through the hardware store today and saw a bigger than normal poulan chainsaw and noticed the engine tag said 52cc. Thas any one converted one of these?? are they good powerhouses?? Im thinking of one for my next project but they cost 250.00 !! Im sure I can find them cheeper some place else. thanks for any info!
Old 02-23-2003 | 04:09 AM
billzair,
The largest one I have converted is a 50cc from a model 310.
Go to the Poulan web site and look at the parts list diagram for the saw model you found. If the motor is a separate unit - they convert easily. If the crankcase is part of the saw - it takes a lot more machining and the weight goes up.
The largest one I have found as a separate unit is the 310 which is 50cc.
Dave
Old 02-23-2003 | 08:05 AM
Actualy the ones with the case you have to trim are generaly lighter because the case is magnesium,lighter and more rigid.To top it off I can make a mount plate for the cut case at 1/3 the weight of the h9 mounts so you save even more weight.
ps my 59cc stihl motor weighs 1/2 lb. lighter than my poulan 46
ready to mount with alot more poop!!
Darin
Old 02-23-2003 | 03:20 PM
That's very good information - which model# saw is the 59cc in. My Poulan 50cc weighs 3.9lbs total up fly weight (RCIgn conversion). If I can get 10 more cc's for minus 1/2 pound I would be very interested in the used saw market again.
Dave
Old 02-23-2003 | 04:52 PM
yes I think I have that there info,I belive it to be a 031 58.5cc I have it striped down to replace the bearings,so when I get it put back together I will post a picture.
Darin
