CH Ignition power consumption - Brison 3.2 ?
AZ
Hello,
I was wondering if anyone knows the typical current consumption of a CH ignition (used on a Brison 3.2) ??
I'm interested at 4.8V and 6.0 V. The reason I ask is the other day my ignition batt gave up pretty fast. The engine began running very rough. I was using a 4.8 1100mah ignition pack which should be adequate - I thought ?. After the first 10 min flight the pack voltage was at 4.8 V. The pack is fairly new but maybe it's failing ? I'm still investigating.
I replaced it with a brand new 6.0V 1700 mah pack and the engine is running perfectly. After three 10-15 min flights the pack voltage was 6.2V - is this OK ?
What is the lowest voltage (using a 6.0V pack) that the ingintion will work well ? I want to be able to predict how long the ignition will operate properly.
Thanks, Eric
Thanks, Eric
RE: CH Ignition power consumption - Brison 3.2 ?
Sounds like your 4.8 volt pack is not up to snuff. I don't have the exact numbers for consumption, but I'm recalling something about 400mAh for the single plug CH. TKG will probably come in here and correct me if I'm wrong.
I don't know about that particular ignition system but I run the Thor 45 cdi and the 600ma 4.8 vdc battery would only last a matter of minutes before the engine began to run rough. I am now running a 2600ma 6vdc battery and am not having any problems so far.
AZ
Out of curiosity (and I was a little bored []) I rigged up a little extension that allowed me to insert a meter to measure the current comsumed by the ignition. With a 5-cell ignition battery measuring 6.5v (loaded) I measured 390ma at idle and 600ma at full throttle. This also helps me rule out ignition issues related to my quick battery demise as mentioned earlier.
Now I only have one more question:
Q. When using a 5-cell ignition battery at what voltage will the ignition not provide good spark - what's my "go home" voltage ?
Thanks, Eric
Thanks, Eric
My Feedback: (13)
OH
don't know how safe it is but i run my 5 cell ignition packs down to 6.2,they are 2500ma from wallmark,you can get them for $17.00 for a 8 pack.engine still runs good at 6.2.
ENJOY!
ENJOY!
WY
Rule 1 As your battery voltage goes up so does the current drain. Soooo a 5 cell pack won't last as long as a 4cell pack.
Rule 2 The ignition will run at a lot lower voltage than your battery can provide when its totaly discharged. Your battery will run out of current before voltage becomes an issue. The engine will start to show a high speed miss as the battery runs down. Its giving you about a 2 minute warning, SO LAND.
WI
Eric,
May I suggest going to the NoBS Battery site and read up on ingnition batteries and what is needed. I ended up with a 2/3 A 4cell nimh. It works great and can fly all day with the CH and not worry. No need to carry around that 5 cell pack. That extra battery is extra weight and does not make any differance to the CH ingnition modules. Also if you are thinking the 5 cell will run longer than the 4 cell it is not true.
AZ
Thanks for the info !
The reason I went with the 5-cell ignition pack was it was the only known-good one I had. Since the 4-cell pack was giving me trouble I swapped it to test. Trust me, after buying every carbon fiber accessory known to man (ya gotta admit the CF spinners are cool looking) to save weight since I fly a 5000 ft MSL it was painful to add extra weight [X(]
I'll be ordering a new 4-cell ignition pack tomorrow !
AZ
I figured the "Riverton" connection. Very valuable input - I appreciate everyone's patience !
Wouldn't a 5 cell pack give a form of redundancy (similar to 5 cell receiver packs) in case one of the cells shorted? I don't mind carrying an extra ounce or two if it means my engine doesn't quit at a bad time. Not that there's ever a good time
I'm considering this on a G62 converted by Ralph.
