Switch for ignition.
My Feedback: (37)
MI
I've got an RCS140 installed in my 93" Citabria, which is my first gasser. My question is, do I need a special switch for the ignition. At the moment I've got a standard switch from a standard flight pack from ServoCity.
Tim
Tim
My Feedback: (37)
MI
Are you saying to keep the ignition switch away from the ignition box and battery. I was under the influence that they could be in the same area as long as the ignition system, as a whole(ignition box, battery, switch, and engine) was kept at least 10"-12" away from the radio system(receiver, battery, switch, and servos).
Tim
Tim
FL
No, I didn't mean away from the ignition module. I meant just what you had been told, keep all ignition components away from the receiver, battery, etc.
Just separate the two systems as much as you can.
FL
You are going to have more vibration in a gas powered plane than a glow, so I would definitely recommend a heavy duty switch vice the standard one.
Lynn
Lynn
