old gas engine
Old 09-03-2007 | 12:11 AM
Hisham's Avatar
Default old gas engine
Guys
I need ur help,[]
anyone familiar with this old gas engine,
need the manual or instructions for this one,..
Any kind of info is greatly appreciated.
Thanks a lot.
Hisham
ID:	755652   Click image for larger version
ID:	755653   Click image for larger version
Old 09-03-2007 | 09:13 AM
Default RE: old gas engine
I'm going to go out on a limb and say it looks a lot like a Power Products engine I had back in the late 60's. Other than that, I can't help ya.
Dr.1
Old 09-03-2007 | 12:47 PM
Hisham's Avatar
The wiring seems a bit confusing
any opinions about the kill switch wires and
what should I power the ignition with...
Hisham
Old 09-03-2007 | 01:38 PM
TLH101's Avatar
My Feedback: (90)
Don't know what it is is, but appears to have some sort of and electronic ignition conversion on it. There is a trigger, or some sort of selfcontained ignition on the flywheel.
Might post in the "conversion engine" forum. Maybe someone there will know.
Old 09-04-2007 | 06:24 AM
Looks like an R/C-type connector for a battery supply to the electronic ignition. The large red wire is the kill switch wire. Simply connect that wire to the crankcase through a SPST switch. It grounds the primary side of the ignition.
Dr.1
