Da 85 feedback?
Some of the early 85s had an issue of the hub being too close to the front of the motor. DA suggests a .040 gap there minimum. Anything less and it should be returned for service. Mine was .005 and i found out about it before running the motor. I sent it back in for service yesterday......Gene
My Feedback: (44)
ORIGINAL: krayzc-RCU
JTEC is tested by DA from what i understand to get 200 more RPM
http://www.jtecrc.com/
When I talked to someone at DA they said that JTEC did their own testing and Slimline was the muffler tested by DA. I was also told that the Slimline gives slightly better RPM. Whose info is correct? I don't know...;. I am using the Slimline and getting 6750 RPM on a PT 26x10 prop. My impression is that there is still quite a bit more vibration as compared to my 3W-106 twin on another airplane. Seems about similar to the DA-50 vibration on a smaller airplane.
Krayzc, I sent it back with out takeing any pics of it. I just started building the comp arf Extra that its going in yesterday, so im really going to be looking foreward to getting it back though. I finished building another carf Extra yesterday morning and we hope to test fly it today if the wind gods co-operate! This one has a Evolution 58 in it and im anxious to see how it flies on that. I should mention these are 2.3 carfs. It came out on the heavy side and we cant figure out why, even put in carbon tubes, titanium tail wheel etc..20 lbs 14 0z. Im putting the 85 in mine, and allready know throttle mgmt will be imperative. I plan on running a 3 blade 24-10 and that should help suck up some of the power though. I had the plane and the motor became available, so im gonna give it a whirl. Been talking with others that put in zdz 80s and larger and had no problems so we'll see.......Gene
TX
My experience is different. I have two 35% right now, an Edge with an 85 and I Giles with a DA-100. I've been flying them alternately, fly one while I work on the other.
To be honest I can't see much difference between the two engines. Equal in smootness, equal in power, both start easy, spin the same prop, use about the same amount of fuel. The major difference is the 85 is 1.75 lbs. lighter and $350 cheaper, and uses a single canister instead of two, saving another $150 and 1/3 pound.
TF
TF
