Theoretical Thrust Calculation
Old 11-13-2007 | 01:18 PM
Default Theoretical Thrust Calculation
Can you point me to a "Chart" that shows theoretical thrust based on RPM, Prop diameter, pitch and, I assume, altituted...
Murphey (As in Murpyey's Law)
Old 11-13-2007 | 01:36 PM
Default RE: Theoretical Thrust Calculation
Get me your email address and I will email you the Prop Power Calculator. It is as close as you can get.
[email protected]
Chad
Old 11-13-2007 | 01:38 PM
Wait....here is a link to it on the web:
www.mvvs.nl/prop-power-calculator.xls
Chad
Old 11-13-2007 | 06:49 PM
Chances are good that if you make the calculations and then measure the thrust on several props you will never make the calculations again.
Bill
Old 11-14-2007 | 09:15 AM
I would say those chances are GREAT Bill
Nothing is better than trial and error with a good set of props and exhausts. The theoretical approach, and opinions of others are fantastic starting points, but if we never experimented beyond that, we'd never know what the perfect setup was for ourselves
Chad
Old 11-14-2007 | 11:09 AM
Chad,
I believe in the theoretical approach and encourage you to experiment and post the results.
Bill
Old 11-14-2007 | 11:54 AM
Amen brother.... the most i have done with the prop power calculators is point other inquiring minds to them, beyond using it for a good starting point for myself on some new projects.
Chad
Old 11-14-2007 | 12:30 PM
RTK's Avatar
RTK
ORIGINAL: arobatx
Chad
arobatx--That one by Pe has been the most accurate one I have found when comparing it to my trusty old fish scale.
Old 11-14-2007 | 12:57 PM
Yup, I agree...it is as close as you can get, as I originally posted about it. Pe did a really good job with that. He spills a ton of knowledge onto the rest of us here, and it sure is appreciated.
Chad
