gas twins
Old 01-06-2008 | 01:18 AM
Default gas twins
Looking for a twin in the 45-50cc range narrow enough to fit within a 240mm wide cowl WITHOUT having to cut clearance holes for the plug caps. The Roto 50 is almost there, not quite. 3W48 is too wide, way too expensive. What else is out there? Don't want glow for this plane.
Old 01-06-2008 | 03:57 AM
Rcpilot's Avatar
My Feedback: (78)
Default RE: gas twins
Whats 240mm? This is America man!!
This one is 10" from plug cap too plug cap:
http://www.rcguys.com/engines.html
Old 01-06-2008 | 10:02 AM
240mm is 9.44882 inches will be hard to find a twin narrower then that. get out the dremel or another idea.
Old 01-06-2008 | 10:34 AM
Bill Diedrich's Avatar
Trt this one for your plane:LS Pro engines Has a 50cc twin that is 9 1/4" cap to Cap:
http://www.lsproengines.com/lspro_006.htm
http://www.lsproengines.com/lspro_016.htm
Edited to remove comma (,) after 1st link. Works fine now.
Old 01-06-2008 | 10:38 AM
My Feedback: (264)
My moki/rcs 44cc twin is 10", I also have the DZY 48cc twin and it is about the same.
Old 01-06-2008 | 10:42 AM
mrbigg's Avatar
My Feedback: (21)
I wonder if it's possible to build a V-Twin 2 Stroke. Kind of like the European Laser 4-Strokes. It would probaly make alot of scale guys happy.
Old 01-06-2008 | 11:58 AM
Try RC Guys in Canada, they have a 48 cc twin that may due the trick
Wilki
Old 01-06-2008 | 12:07 PM
Stickbuilder's Avatar
Ken,
Saito has the narrow V-twin that might work for what you want. It's pretty pricey for what you get though.
Bill, AMA 4720
WACO Brotherhood #1
Old 01-06-2008 | 04:13 PM
Thanks for the replies. Looks like the LS Pro is the winner by a scant 1/8 inch. There's actually a tad more, maybe 1/2 overall, which will work. At least I know there's something out there. I thought my ZDZ-50NG was going to fit, but it missed by 1/2 inch with the plug cap on (this is for a 1/4 scale BirdDog). I'd rather not have to cut the cowl, even underneath, but I really want to use this engine, although the thought of the twin is attractive, since the cowl has those "nostril" intake holes in the front, you'd be able to see the cylinders. Lots of time to think it over.
Old 01-06-2008 | 05:41 PM
Give Larry a call @ LS Pro he would really like to hear from you and will discuss any
aspects of this engine you would like to hear about. I am going to pick one up late this
year to put in a Nosen Mr. Mulligan. Also thinking of trying out the 26cc he has for my
quarter scale Pitts S2B.
Old 01-06-2008 | 05:51 PM
ORIGINAL: mrbigg
a vtwin 2stroke can not properly operate without 2 cranks and a pinion. the configuration can not use a common crankcase. sorta like the 2 stroke radials
Old 01-06-2008 | 08:08 PM
My Feedback: (43)
2-stroke v-twin is possible if it is a port induction and not reed valve. You will have to have two carbs and two fuel systems, or at least two clunks in the tank. It would also require a pressurized fuel system, or suction feed since the two pistons would cancel out changes in crankcase volume to operate a walbro type pump. It is probably not effective, but I think it is possible. It would sound like it is turning twice as fast as it really is since there would be two power strokes per revolution.
Old 01-06-2008 | 11:50 PM
soarrich's Avatar
My Feedback: (98)
ORIGINAL: Bill Diedrich
And he has a conversion kit to go to the little sparkplugs, which will make it even narrower. I have the 50 twin, IMHO the best of the LS's.
Old 01-07-2008 | 11:35 AM
DKjens's Avatar
My Feedback: (50)
ORIGINAL: JeffH
540horses is absolutely right. What you say cancel out the pump action on the carb. do the same on the transfer ports in the engine. A single crankcase V-Twin 2-stroke could possibly be made if both pistons were at TDC and firing at the same time, but it would be hard to balance and probably not that efficient.
khodges, remember to take any right thrust of the engine into account when measuring your clearance. Very often the left cylinder sits quite a bit further off center than the right cylinder due to the right thrust.
Old 01-07-2008 | 06:30 PM
soarrich's Avatar
My Feedback: (98)
ORIGINAL: JeffH
Actually I think you'll find that with a two throw crankshaft to get both cylinders a TDC at the same time it will work fine, and be pretty smooth. The primary imbalance of one cylinder cancels out the secondary imbalance of the other and vise verse if it is a 90* v twin. Think Ducati, Yamaha and Suzuki twins, the Honda Shadow v twin had off set journals to give some character to the motor, HDs are just messed up balance wise.
Edited to remove profanity.
Old 01-07-2008 | 10:06 PM
[quote]ORIGINAL: soarrich
ORIGINAL: DKjens
ORIGINAL: JeffH
the crank would have to have different strokes with higher piston speed on the rear cylinder to catch up. it wouldent flow right and would be very inefficient.
Edited to remove profanity from previous poster.
Old 01-07-2008 | 10:17 PM
skiman762's Avatar
ORIGINAL: khodges
How are going to cool it if you don't open the cowl up ?
Old 01-08-2008 | 06:55 PM
ORIGINAL: skiman762
ORIGINAL: khodges
What I meant was, not open the cowl or make holes where there aren't any on the full scale. Of course the scale inlet openings will be there, as well as an opening at the bottom where the exhausts exit the cowling, which is also sufficient for airflow through the cowl. I'll also have baffling inside to direct air over the cylinder if I stay with the single. If I go with the twin, each cylinder will have a hole directly in front of it. There is no right thrust on the plans, and I won't add any.
Old 01-09-2008 | 10:11 PM
I'm not being a wise guy, I'd really like to know why you'd want a 50CC size twin?
Sound? Or you want it to look like a lycoming?
Multi cyclinder 4 strokes, especially radials, have way less HP then their single cyclinder counter parts. Is this true of gas?
Old 01-22-2008 | 02:12 PM
air hobbies sachs 3.0 has 50cc twin 81/2 in plug to plug. air hobbies.com
Old 01-22-2008 | 04:40 PM
SON OF PALEFACE's Avatar
this looks remarkably like the same engine , and prob a lot cheaper........
had to edit it out . had my info on it[]
Old 01-22-2008 | 06:27 PM
soarrich's Avatar
My Feedback: (98)
Yes, and when you have a problem you'll call LS Pro, because you don't speek Chinese and don't want to pay $50 each way to China for service. I hope LS Pro has the Ba... to tell you where to get it serviced.
Old 01-22-2008 | 08:38 PM
Rcpilot's Avatar
My Feedback: (78)
Take it easy Rich. There's no need for the foul language in the forum. He's from Australia, I doubt that he will send his engine to the USA for service.
Old 01-22-2008 | 09:19 PM
RC Extreme power's Avatar
My Feedback: (24)
even if it will fit in the cowl one plug will probably still have to stick out one side because of the off set for right thrust.
Edit
Just read your post about no right thrust but ??????
Milton
Old 01-22-2008 | 09:42 PM
Yeah Rich just relax , the amazing thing is. all the people you can buy from in Hong Kong and elsewhere in that part of the world , all speak pretty good engrish....Ha-so ...
Obviously shipping is much cheaper for us , like $24.77 for a 26cc SV engine from United Hobby and it runs really good....APC 16x8 @ 8000....another one I got from HK had a crook carby , they sent me a new one and I had to send back the crook one .....cost me $7.00
